Author Topic: Exhaust  (Read 10101 times)
Online Jack Gifford
Exhaust
« on: October 30, 2017, 01:32:50 AM »
Rulebook says, in part,- "... directed away from... the course...". The exhaust will exit one side of my lakester, with no turn to the rear planned. The present stacks would be aimed 12 degrees down from horizontal. Must they be fully horizontal to be considered 'away from the course"?
M/T Pontiac hemi guru
Offline MRK
Re: Exhaust
« Reply #1 on: October 31, 2017, 11:03:14 AM »
If the exhaust exit is pointing downward past a horizontal plane, isn't that "towards the course"??
My suggestion is to run your design past the Chief Car Inspector and Committee Chair for approval. The contact info is in the rule book.
Cheers
"Racing is life. Anything before or after is just waiting." Steve McQueen
Re: Exhaust
« Reply #2 on: October 31, 2017, 11:30:20 AM »
As long as it doesn't make a big dust cloud I don't think it will be any issue---Jack you may want to visit your aero coach about the straight exhaust he may think that that is the same as sticking a 3' 4"x4" out the side of the car
Re: Exhaust
« Reply #3 on: October 31, 2017, 02:07:39 PM »
Jack,
I agree with Sparky, just having them stick out the side is not to "aero" and then not pointing them to the rear is just like throwing away horse power. Just to do a quick calculation with some easy numbers let's assume that your exhaust produces 25 lbs of thrust, which might not be to far off for a small supercharged engine, at 200 mph that is 133 horse power! Can you afford to do that?
I have always like what the Contrivance Engineering guys do with their exhaust.
Re: Exhaust
« Reply #4 on: October 31, 2017, 06:42:59 PM »
Yeah, but what do they know.
Offline ronnieroadster
Re: Exhaust
« Reply #5 on: October 31, 2017, 08:15:25 PM »
Jack,
    Rex if the numbers are close to accurate using 25 lbs of thrust pointing rearward would it not be disrupted by the exposed rear tires rendering the hopeful push forward non existent? Or little if any noticeable.
  Ronnieroadster
Re: Exhaust
« Reply #6 on: October 31, 2017, 08:46:28 PM »
....I have always like what the Contrivance Engineering guys do with their exhaust.....Rex
I'm not a fan of the exhaust going straight out either.  We had it that way on the Stude, but were hopefully going to change it.
I like what they did on the prop planes during WWII and probably other times, as shown above, on a Spitfire.  Somewhat similar to Contrivance.
If I was ever to finish the lakester it has it exiting rearward and would also help the CP/CG as shown above, above the chute doors,
Online Jack Gifford
Re: Exhaust
« Reply #7 on: November 01, 2017, 12:35:49 AM »
Thanks guys. I'm still a long way from concerns about any thrust from the exhaust, but adding bends could definitely eliminate "exhaust directed at course".
Re: Exhaust
« Reply #8 on: November 01, 2017, 04:06:20 AM »
 We bend them back and up. Thrust and down force.
Offline jacksoni
Re: Exhaust
« Reply #9 on: November 01, 2017, 08:22:51 AM »
Though I don't know for sure I suspect this rule is directed at cars with under the car exhaust systems rather than special construction or others where fender exits are legal. My engine uses a very short header (so very hard to lengthen to direct toward the back of the car without messing up my exhaust tuning) and it was pointed more or less at the track, about 10" away. They made me put a deflector on the outlet. The prior suggestions are all valid but I don't think anyone is going to ding you if an exhaust coming out the side of the car is slightly pointed down (therefore "at the track") from 18" or more above the ground. But then again......
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Online Jack Gifford
Re: Exhaust
« Reply #10 on: November 01, 2017, 11:47:34 PM »
Historical note: this SCTA rule goes all the way back to 1948 (at least), so I'm guessing the main concern was kicking up more dry lakes dust.
Offline floydjer
Re: Exhaust
« Reply #11 on: November 06, 2017, 08:37:29 AM »
May as well add augmentation tubes while you`re at it :cheers:
« Last Edit: November 06, 2017, 10:07:45 AM by floydjer »
Re: Exhaust
« Reply #12 on: November 06, 2017, 10:03:45 AM »
notice the slight bellmouth on the planes exhaust----nothing like a little designed in low pressurer  to help extract the exhaust
Offline wickedwagens
Re: Exhaust
« Reply #13 on: November 15, 2017, 10:31:25 AM »
Back and slightly up on the Clark/Hall lakester.  They also make a great rest for tools ect.
1968 Volkswagen Karmann Ghia
G/CFALT  106.643 MPH  8/2016    G/CGALT  113.131 MPH  9/2016
G/CBGALT  169.462  MPH  8/2021    G/CBFALT  146.715  MPH  8/2017
G/CBGC  158.242  MPH  9/2017   H/CBGC  94.334 MPH  8/2018
H/CPRO  93.383 MPH  8/2018   H/CBFALT  101.282 MPH 9/2018
H/CBGALT  120.591 MPH 9/2018
Top Speed 170.726 MPH
36hp VW 100 mph club 9/2019 102.319 MPH
Offline John Burk
Re: Exhaust
« Reply #14 on: November 15, 2017, 01:27:47 PM »
Eric Ahlstrom advised swept back and flush .
