Author Topic: Bockscar 2.0  (Read 465877 times)
Offline jacksoni
Re: Bockscar 2.0
« Reply #720 on: June 01, 2020, 08:03:53 AM »
Stainless- how long is the scoop and rectangular to round adapter? if that is a full sheet 4x8 plywood it is sitting on looks to be close to 48" total with maybe 60% being the NACA part/
Do you anticipate being ready for this year?
Jack
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Re: Bockscar 2.0
« Reply #721 on: June 01, 2020, 10:46:00 AM »
Jack, the opening for the scoop is about 18 inches... the transition duct is about 8 inches...
I think we will be ready for SpeedWeek... I'm entered.  :cheers:
Offline jacksoni
Re: Bockscar 2.0
« Reply #722 on: June 01, 2020, 10:50:41 AM »
Thanks. Hope to look you up on the salt.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline floydjer
Re: Bockscar 2.0
« Reply #723 on: June 01, 2020, 06:55:06 PM »
Good luck on completion Bob....Maybe you should take El Kabong with you and bury him in a place of honor?
Re: Bockscar 2.0
« Reply #724 on: June 02, 2020, 12:09:47 AM »
Dang Jerry, he's only injured... not dead...  well ok, he is a dead blow... but he really has been assigned light duty tapping the draw bar on the mill when I change tools... a job he volunteered for rather than go on disability and unemployment.... he's a trooper  :friday
keep moving... the scoop panel has now been marked for the cut out and mounting rivets... next up, chop into the panel.
Been working others stuff too, emergency chute release... have a plan and half the parts made.
Steering wheel wiring... in work
Battery cables, determined lengths and routing, going to the battery cable store soon.
Re: Bockscar 2.0
« Reply #725 on: June 05, 2020, 10:18:56 AM »
Panel cut for scoop, scoop attached and final adjustments made to air box mounting.... then fire doors laid out on the engine panels, one on the left, two on the right... Pictures will show up for those after doors are cut and mounted.
Welded the mounts for the electrical cutoff, finished the hole in the hood, added a Dzus fastener close to the cutoff to keep the panel from oil canning and shutting the car off.
No that is not the final marking... I'm thinking a red circle or what ever is the universal symbol for electrical shutdown, we will see
Re: Bockscar 2.0
« Reply #726 on: June 08, 2020, 01:01:24 AM »
Finally took a few pics of the stuff I've been working on.
Brake and clutch lines are bent and installed... flex lines on both ends of hard lines.  The masters are adjustable on slides so lines allow movement.
The battery cables are installed from battery to the firewall.  Switch is mounted.... the white thing... it's a reset tool for the switch.  I decided it was too difficult to reset the switch when it was flush with the panel, so I drilled a couple of holes in the switch cover and made a spanner.  Might make another one for just in case....
Parachute manual backup is installed and mounted... yes I write notes on tape
Fire bottle activators are mounted, one tab to weld for the adel clamp and that system is done.
Anyone know how to  buy just the push button, one of mine is cracked  :-(
Offline Jack Gifford
Re: Bockscar 2.0
« Reply #727 on: June 08, 2020, 01:11:51 AM »
Do you always run it 2,900 rpm for photo shoots? 8-)
I'm curious what your fire bottle activators look like (with push-to-activate cables). My FireFox bottles use pull cables which release the spring-loaded diaphragm-piercing needle.
« Last Edit: June 08, 2020, 01:20:26 AM by Jack Gifford »
M/T Pontiac hemi guru
Re: Bockscar 2.0
« Reply #728 on: June 08, 2020, 01:20:58 PM »
2900 RPM... you have been paying attention... Autometer tachs never seem to say 0 unless power is applied.
The cable is basically a Morse type, flexible but solid.  The firebottle cap has a piercing pin and the cable pushes it through the diaphram.  The second pic on my last post shows the gold cap with the cable attached to the 10 lb #2 bottle.   Yes, you better have a pin in the bottle with the cable off or the cable when it is on.
Still searching for a "Fire Push" button  :cheers:
Offline SPDRACR
Re: Bockscar 2.0
« Reply #729 on: June 08, 2020, 06:55:14 PM »
Bob, Try Ed Fenn at FSR 951-three zero six-7870 West coast time
leave message if no answer
salt is OK, but the DIRT is where it's at!
Proud 2nd generation Roadster Racer
Muroc 2 club, El Mirage 2 club, Now Bonneville 2 club,       All in a Roadster
Re: Bockscar 2.0
« Reply #730 on: June 14, 2020, 10:00:32 PM »
Talked to Ed... we have hope, the has similar that may need bushed 3/8 to 1/4 but I believe we have a winner.  Sounds like he is LSR friendly, is on the salt, knew my old car... and seemed very reasonable... and guys, he will inspect and tag on the salt.... in case you forget....
Been working on a lot of little things... added some tabs, painted all the unpainted additions to this point, changed orings in fuel system to fluorosilicone, doing lots of nit noi stuff... you know, the stuff that takes lots of time and doesn't look like you are doing anything  :?
Ross was over so we bled the clutch and brakes... Made a few more PTFE fuel lines... added the pull strap
Planned the lateral head restraints... yes, there is so much room in the cage that I need to add filler... in the old car you had to work to keep your helmet in the 1/8 inch of extra space so it didn't rattle your eyeballs...
should have some pics of that in a week... basically adding a 2x4 on each side... OK, a metal 2x4, they are on the way here but it will take time to get them.
Offline floydjer
Re: Bockscar 2.0
« Reply #731 on: June 15, 2020, 05:47:20 PM »
Keep that stuff up and you WILL make it... :clap I may have to strong -arm the Tiny Terror in to a road trip to watch the maiden pass. :cheers: JB.
Re: Bockscar 2.0
« Reply #732 on: June 16, 2020, 09:22:06 AM »
Still trudging that direction....  :wink: finally got the last parts of the fuel system so I could make the last hoses and get them installed... now all I need to do is mount the 20 micron final filter... working on that plan.
Picked up a battery, worked the hold down from a piece of aluminum I had laying around.  Had some silicone hose left over from the cooling system, so it is shock (no pun intended  aktion086) mounted.  And yes, I disconnected it after the photo op, still a few things to do in the electrical system  :-o
Still waiting on parts, maybe some will get mailed today since they weren't sent yesterday... hard to get good help.
Re: Bockscar 2.0
« Reply #733 on: June 17, 2020, 10:03:43 AM »
Remember those 1 gauge welding wire battery cables... I went back to have some other sizes made.  I learned after I got them home that they didn't have the size ends I requested, so they made them with the size they had.... at least they got the  4 gauge welding wire right and made it long instead of short.
Well that was a problem... I couldn't find anyone else, so I took matters into my own hands.... it was an opportunity to own another tool.  10 ton hydraulic crimper... it was cheap, under $40 from Jeff's China store, delivered.  The reviews said it works... the instructions on use... insert proper die for wire and lug, pump handle.... no word on how you figure out what the proper die was, but I got it right by the 3rd try.... no wire or terminal lugs were wasted in that effort.  :-D  Waiting on 1 gauge terminals to do the last cable crimp.
It came with 9 sets of dies... I'm not thinking it was built to fail, but it also came with a rebuild kit  :?
Ordered a $10 billet clamp mount for the fuel filter... don't know how they can sell them for that.
Re: Bockscar 2.0
« Reply #734 on: June 19, 2020, 12:06:35 AM »
Wait... sell them for under $10 and deliver them in 2 days....
Clamp showed up, then it was time to figure out how to mount it...
Fuel system is done... well almost, I need to test my fuel safe foam in the tank to see if it gets along with E85 and Methanol.  So far, everything else in the system is compatible with all three.
