Author Topic: Bockscar 2.0  (Read 464251 times)
Re: Bockscar 2.0
« Reply #585 on: January 08, 2020, 11:55:02 AM »
Well it's been a while and a lot has happened...We enlisted some help from our friend Rory Andrykowski, the artist that painted the original nose art on the car back in the 80's.  The crash destroyed the nose and the art...
Working from a couple of pictures, the original airplane and our old art, Rory managed to update our art and get it on the new nose.
Re: Bockscar 2.0
« Reply #586 on: January 08, 2020, 12:00:32 PM »
Yes guys, the new nose art is going to be shown...  aktion086
Re: Bockscar 2.0
« Reply #587 on: January 08, 2020, 12:13:12 PM »
And yes, the body is done and I brought the car home and put it in the shop yesterday.
Next up is take the body off, paint the frame and put it back together
Offline Calkins
  • On Any Sunday
    • Facebook
Re: Bockscar 2.0
« Reply #588 on: January 08, 2020, 12:14:52 PM »
Love it!!!
Offline ggl205
Re: Bockscar 2.0
« Reply #589 on: January 08, 2020, 01:55:22 PM »
Looking very slippery there, Stainless. The new car turned out exceptionally well. Can't wait to see it run. Who knows, we might be out there with you this year.
Re: Bockscar 2.0
« Reply #590 on: January 08, 2020, 02:12:47 PM »
That is looking SO great!!
Offline salt27
Re: Bockscar 2.0
« Reply #591 on: January 08, 2020, 02:30:31 PM »
Stainless, sorry if I missed it but what is the frontal area comparison between old and new?
Re: Bockscar 2.0
« Reply #592 on: January 08, 2020, 02:35:02 PM »
Looking fast Stainless. Nice work!  :cheers: :cheers: :cheers:
Offline Speed Limit 1000
Re: Bockscar 2.0
« Reply #593 on: January 08, 2020, 08:20:06 PM »
Almost the same. The lower part of the car is still 24" wide and 16" high. The roll cage is about 5/8 inch bigger. The canopy is larger to miss the cage. The engine cover stays the same as the canopy till past the motor then tapers to the tail. The other engine cover was smaller for the 750cc motor but had bumps to clear the Busa. Computers say the new car should go through the air better because it is smoother. We hope to find that is the case at Speed Week.
John Boy
Re: Bockscar 2.0
« Reply #594 on: January 08, 2020, 09:19:19 PM »
SS & John Boy --
Hope to see you this year and get a taco, ice cream and recap at the one and only combo merchant (yes, I know it's changed a little).
(Where in the fukk do these ???s come from?)
Re: Bockscar 2.0
« Reply #595 on: January 08, 2020, 09:31:34 PM »
SS & John Boy --
From the ??? fairy cromag
Offline salt27
Re: Bockscar 2.0
« Reply #596 on: January 08, 2020, 10:29:47 PM »
John Boy
Thanks, the new body sure looks slick.
Re: Bockscar 2.0
« Reply #597 on: January 08, 2020, 11:57:15 PM »
Not to worry, we will dirty up the air with wheels and axles...
The top is larger, about 3 inches wider than the old one at the base... but Pork Pie says our motor bumps were slowing us down and since we needed to build in more helmet room, I made it to accommodate the motor as well, at least that is our hope... let you know when I put a motor in it.  With any luck the air will flow smoothly down the top.
The nose is all glass and and will not have a fresh air vent on the side like the old one.  The fresh air vent is in the cowl... I'll pop a pic of that in here at some point.
Stan I think Jon is screwing with us... special characters seem to generate ??
I am on another forum and occasionally see a ? where a "quote" would be.
we will see  :cheers:
Offline PorkPie
  • think fast.....always
Re: Bockscar 2.0
« Reply #598 on: January 09, 2020, 03:00:38 AM »
As Stainless wrote, the roll cage size increase to get more space for the helmet.
This did not effect the frontal area that much, as the bump in the old cover for the engine compartment was larger, anyway.
so, here some numbers.
the frontal area is app. 3 percent smaller than the old one
the drag, if the rough simulation is right, will be 12 percent less
two other number changed also, here we have to see what it means for the handling
the downforce from the airflow over the body is less than the old one
and the CP moves about 5 inches forward.....
with the cleaner airflow the car will be better controlled by the airflow to go straight...
it is a plus and minus....the white dyno will tell what the real increase of speed will be
but finally the condition of the salt surface has to be right to turn the advantage of the improvements into speed
Re: Bockscar 2.0
« Reply #599 on: January 09, 2020, 12:38:53 PM »
As my 5 year old Great grand would say " It looks sliperreey!! :cheers:
