Author Topic: Bockscar 2.0  (Read 465186 times)
Offline ronnieroadster
Re: Bockscar 2.0
« Reply #555 on: July 28, 2019, 01:34:02 PM »
Yes it has been quiet here... the car will not make SpeedWeek... still body building and a lot of other work to be done.  I took the car to Denver for sheet metal work and then joined it last week to do fiberglass.  Pictures to follow soon, a little busy right now.
Yep that means I have a pre-entry to sell to you or the SCTA...  :cheers:
I will be at SpeedWeek crewing for Ross (MC2032)
   We all understand the amount of work its takes to do any of this is simply huge.  Now on the bright side you will be able to relax at Speedweek sort of taking a vacation from working so much on the car we all need a brake at times.    :cheers:
Online Stainless1
Re: Bockscar 2.0
« Reply #556 on: July 29, 2019, 09:41:48 PM »
Hardly know where to start... so I'll throw out some pics of what is/was happening.  We will start with the nose.  You saw the bare piece... from there it got paint... then fiberglass then gel coat... may get more gel coat... or a skim of body mud to smooth it all out.
Online Stainless1
Re: Bockscar 2.0
« Reply #557 on: July 29, 2019, 09:51:27 PM »
Then the canopy...
Online Stainless1
Re: Bockscar 2.0
« Reply #558 on: July 29, 2019, 10:12:35 PM »
And engine cover
Online Stainless1
Re: Bockscar 2.0
« Reply #559 on: July 29, 2019, 10:27:46 PM »
Then we started fitting it all to the frame...
Cutting the opening for the windshield
Re: Bockscar 2.0
« Reply #560 on: July 29, 2019, 10:30:17 PM »
Looking good, Bob!
Online Stainless1
Re: Bockscar 2.0
« Reply #561 on: July 29, 2019, 10:41:10 PM »
It is getting some sheet metal as well... using .063 aluminum... you might be able to see the direction we are going
The canopy hinge is installed and I came home to get ready to go back.
Re: Bockscar 2.0
« Reply #562 on: July 30, 2019, 01:48:01 PM »
Stainless,
Looking great! Good progress, you are getting down to the "only about a hundred 5 minute jobs left" area which of course there is no such thing as a 5 minute job it means you have plenty to do.
Looking forward to seeing you at the salt.
Online Stainless1
Re: Bockscar 2.0
« Reply #563 on: July 30, 2019, 03:19:21 PM »
Rex, gotta be there to see you do 222  :cheers:
Offline Lemming Motors
Re: Bockscar 2.0
« Reply #564 on: July 31, 2019, 04:01:29 AM »
That is looking really nice.
Hope to meet at the salt in a couple of weeks.
Just a squeeze.
Offline Simspeed
Re: Bockscar 2.0
« Reply #565 on: August 02, 2019, 11:20:27 PM »
Great progress Stainless...looks really good. Excited to see the finished product... Terry
Online Stainless1
Re: Bockscar 2.0
« Reply #566 on: August 19, 2019, 12:45:46 PM »
OK, since we weren't going to get anything done for a couple of weeks due to SpeedWeek and travel we put the nose on a box and pushed it to the car... just to get an idea of how it is going.  Yes the nose needs trimmed about 2 inches to square it up...
As we build the body, we are are changing our plan as we go....
I am home now, but headed back to work on the body in a couple of weeks.  Of course Dave will be working on the parts we already re-thought and hopefully improved
Offline STICK777
Re: Bockscar 2.0
« Reply #567 on: August 19, 2019, 12:52:19 PM »
Looking good... kinda classic.
Re: Bockscar 2.0
« Reply #568 on: August 19, 2019, 01:26:56 PM »
Wow Stainless, it's starting to look exciting. Great work!!!  :cheers: :cheers: :cheers:
Re: Bockscar 2.0
« Reply #569 on: August 19, 2019, 08:42:51 PM »
Nice work, you have accomplished a lot in a short amount of time  :cheers: :cheers: :cheers:
