Author Topic: 2000 Cadillac Eldorado ESC  (Read 13264 times)
Offline GW
Re: 2000 Cadillac Eldorado ESC
« Reply #15 on: July 18, 2017, 12:21:16 PM »
Woz - I'm hoping this picture posts... I too am failing miserably to get pix to post despite the simple to follow 3rd grade instructions (the pic is on my computer, the file type is correct, the file size is less than 500K, etc).
GW
Offline GW
« Reply #16 on: July 18, 2017, 12:22:42 PM »
Sigh... the picture did not post... just a link posted... I am ashamed and embarrassed.
GW
« Reply #17 on: July 18, 2017, 12:42:44 PM »
Click on the link. It comes up perfectly.
Offline TrickyDicky
« Reply #18 on: July 18, 2017, 01:55:33 PM »
If you want the picture to be visible in your post I suggest saving it as a .jpg (rather than .pdf).
« Reply #19 on: July 18, 2017, 02:13:55 PM »
Did this work . . .
Offline woz
« Reply #20 on: July 18, 2017, 02:21:50 PM »
I don't use Photobucket, just took pictures from phone and emailed to home computer as "medium" size. I couldn't do from phone directly.  Woz
« Last Edit: July 18, 2017, 02:35:05 PM by woz »
Offline woz
« Reply #21 on: July 18, 2017, 06:41:14 PM »
The quest for a strong running proper year/version Northstar replacement has begun, I've read a lot about the head stud upgrade that makes them "bulletproof" according to many.  Anybody with some real world Northstar experience that can offer any advice? They are dirt cheap for sure, especially the ones that overheat (like ours) I know the early generation 10 Eldos (early 4.9 non-NS) used the weaker but much lighter 4T60 trans as opposed to the much stronger and heavier 4T80 for the Northstars. I have found a couple of Buick Rivieras with the 3.8 supercharged engines and the weaker transmission at the right price but the electronic complexity keeps me thinking that the NS is the way to go.  Thanks for any input!    Woz
« Last Edit: July 18, 2017, 08:47:00 PM by woz »
Offline GW
« Reply #22 on: July 20, 2017, 12:33:47 PM »
Did some internet trolling... let this be your inspiration...
GW
Offline GW
« Reply #23 on: July 20, 2017, 12:50:57 PM »
Woz - perhaps you've seen this.
"Northstar Swaps - What years are interchangeable and the differences"
http://www.cadillacforums.com/forums/northstar-engines-system-technical-discussion/199946-northstar-swaps-what-years-interchangeable-differences.html
GW
Offline GW
« Reply #24 on: July 20, 2017, 01:09:49 PM »
Is RWD an option?
GW
Offline woz
« Reply #25 on: July 20, 2017, 02:52:52 PM »
Thanks for the links, some good information.  I think I might have found a donor car, it is a 2000 Seville with the same code engine that has been "rebuilt" I am waiting for some sort of documentation regarding what exactly "rebuilt" means.     Thanks, Woz
Offline woz
« Reply #26 on: August 02, 2017, 12:54:31 PM »
The Northstar in all it's glory.  I drained the oil, filled the water and ran as a test.
« Last Edit: August 02, 2017, 01:36:14 PM by woz »
Offline woz
« Reply #27 on: August 02, 2017, 12:56:58 PM »
This is the result, it would appear that the heads are separated from the block.  It actually fires right up and sounds ok! Hardly noteworthy, but I also bought 2 used $10.00 tires to replace the 2 that wouldn't hold air. It is now much easier to move around and I don't have to inflate every day.  I am still searching for a replacement engine that has had mods to heads done or might just tear down this one and see where we are at.    Woz
« Last Edit: August 02, 2017, 08:20:04 PM by woz »
Offline woz
« Reply #28 on: August 31, 2017, 07:42:25 PM »
We have decided to ditch the Northstar and install a conventional aluminum block 4.9 with a non-electronic 4t60 transaxle.  We will be using a single-wire distributor and modified intake with carburetor and aftermarket cam.  This will keep cost low and car much simpler.  I'm hoping to get significant weight out of car once we start stripping out electronics after getting to run.    Woz
