Author Topic: Engine "handicaps"  (Read 17571 times)
Offline Jack Gifford
Re: Engine "handicaps"
« Reply #15 on: June 30, 2017, 01:00:18 AM »
So... anybody know of any SCTA (or for that matter ECTA or LTA) records held by 2-stroke powered 4-wheelers in any class whatsoever? Any qualification attempts by such a machine?
M/T Pontiac hemi guru
Offline krusty
« Reply #16 on: June 30, 2017, 06:30:54 AM »
Someone must have run a Saab 93 or early 96 with the 3 cyl two stroke. Was Bertil's a 3 cyl?
vic
Offline jacksoni
« Reply #17 on: June 30, 2017, 07:21:15 AM »
Definitely have seen a Saab or two at Wilmington (ECTA). Don't know the car/driver specifically so can't find the record though.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline RichFox
« Reply #18 on: June 30, 2017, 10:13:18 AM »
Years ago thete were some Go Kart powered streamliners that ran. I think the Ballpoint Banana may have been two stroke.
« Last Edit: June 30, 2017, 02:52:28 PM by RichFox »
« Reply #19 on: June 30, 2017, 10:59:13 AM »
I remember a car -- liner, I think, maybe a lakester -- running a snowmobile two stroke at the salt.
Offline jacksoni
« Reply #20 on: June 30, 2017, 11:20:26 AM »
What was the power of the little front drive, rear steer (later lakester) from about 20 years ago? I sort of remember it being started with a pull cord like your average chain saw/lawnmower. Had some handling issues so don't know if made a full pass in that configuration.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline jdincau
« Reply #21 on: June 30, 2017, 11:37:35 AM »
I think the "Ballpoint Banana" K streamliner ran a 4 cyl Evenrude outboard 2 stroke
« Last Edit: June 30, 2017, 11:41:50 AM by jdincau »
« Reply #22 on: June 30, 2017, 10:02:33 PM »
Seems like I remember the Hudson Boys running a different motor in this car....
.... but that was 2007 so I wouldn't go on my memory alone  :oops:,
« Reply #23 on: July 01, 2017, 01:33:42 AM »
Thanks for those examples.
« Reply #24 on: July 02, 2017, 09:52:40 PM »
Arnold's Ballpoint Banana was a 2 Stroke Evinrude
The rear steer Liner had two 2 stroke motors
2 strokes were not handicapped as far as I can remember.... but then again, they were only allowed in special construction and motorcycles until sometime in the 90's.  That is when the SCTA decided that non-automobile (motorcycle motors) could be used in other than special construction.
« Reply #25 on: July 04, 2017, 09:00:16 PM »
The Daryll Zipp car from the early 2000's
Offline joea
« Reply #26 on: July 05, 2017, 10:59:05 AM »
an old posts from 2008 about some 2 stroke streamliner cars:
"".... the car you mean is the first streamliner which Tom Burkland built.
A while he runs with a yellow as base color, on the bottom was two orange strip and the top something like purple.The number was 41 and runs in K/GS class - later Zimmermann used the car and changed the base color into red with a checkered flag on and a splashed Duck on the nose, was sponsored by Jaz  ..."ie Jaz Production Special"
In George D. Lepp book "Bonneville Salt Flats" from 1988 is a good picture from the Snoopy version - you can find this book is in the most library."""
This Burkdoll car holds currently the K/GS record. This car was destroyed when Bo Burkdoll rolled the car during the World of Speed in September 2004.
"""...........- the car he asked was the Tom/Gene Burkland built streamliner - Mays runs them originally and set a record in J/GS - before this streamliner runs in K/GS - and as I remember he ownes this record in K/GS too, before it was broken by the the Burkdoll Family. When the car runs in K/GS he used a 443 cc snowmobil engine and had this famous Snoopy Airplane window paintshop on.
Later Zimmermann used the car and run a K/BGS engine for a record which is still in the record list.
The records this streamliner set are - in J/GS 215 mph - in K/BGS 201.7 mph.
The Burkdoll record in K/GS is 202 mph. """
also : http://www.saabplanet.com/saab-96-bonneville-land-speed-record-for-saab/
« Last Edit: July 05, 2017, 11:13:47 AM by joea »
Offline DallasV
« Reply #27 on: July 05, 2017, 02:40:32 PM »
I think Jim Burkdoll set the K/GS in the little bluebird streamliner not the streamliner that was destroyed, if I remember right. The little streamliner that Burklands build for Nick was was the proof of concept car for their big 450MPH streamliner. Good data Joe
« Reply #28 on: July 05, 2017, 07:55:13 PM »
These were two ECTA angry bumblebees!  :x :x :x
Offline ggl205
« Reply #29 on: July 07, 2017, 10:41:57 AM »
I was wondering when a 2-stroke Saab would find its way into LSR. What about the DKW?
