Author Topic: special construction MC fuel tank  (Read 4836 times)
Offline panchop
« on: October 25, 2006, 12:08:49 PM »
 Is there any rule against running the top frame rail AS the gas tank. The AMA rules just want a "securley mounted tank with attention to craftmanship". I have not been able to get my hands on SCTA rules yet and I don't want to take off in the wrong direction.
Thanks
Greg
Offline Nortonist 592
    • http://www.artfv.com/design/fashion/
« Reply #1 on: October 25, 2006, 06:09:36 PM »
I do believe you can use the frame tube as a gas tank.  As long as the frame tube is securely mounted.  Sorry, couldn't resist that.
Offline rockstar
« Reply #2 on: October 25, 2006, 07:35:01 PM »
:lol:  :lol:  :lol:
Remember Murphy's 6th law,if all goes well,then you have missed something out.
Team Sparrow Racing UK
Offline 1212FBGS
    • http://www.motobody.com
« Reply #3 on: October 25, 2006, 10:30:39 PM »
yes its legal. if ya run a fuel class, the fuel valve must be able to be closed without taking your hands off of the handlebar.
Offline John Noonan
« Reply #4 on: October 26, 2006, 12:34:51 AM »
Quote from: 1212FBGS
Kent, please correct me if I am wrong however if he can either shut off the fuel pump or "push" the fuel lever cut-off from the handel bars then they are both  "legal" ?
J
Offline 1212FBGS
« Reply #5 on: October 26, 2006, 01:18:44 AM »
if he uses an electric fuel pump, and it is to be considered as the fuel flow on/off valve, then yes it will work. but all unvalved hoses must be wrapped in fire sleve. and yes he can use a pingle cable switched fuel valve as i use on my GSXR.
Offline ddahlgren
« Reply #6 on: November 23, 2006, 10:13:36 AM »
Most elestric pumps will not stop fuel flow if just turned off electrically, so if it below the fuel level like it should be it will not stop the fuel flow though the engine may stop.
Dave
Offline Larry Forstall
Re: special construction MC fuel tank
« Reply #7 on: December 02, 2006, 12:08:25 AM »
Shutting off power to electric fuel pumps has been allowed in late model FI bikes in both the gas and fuel classes as long as gas is the fuel. When using Nitro or Methanol a true fuel shutoff valve is required. This can be operated by either cable or electric solenoid. (From the handlebar).
Offline JackD
  • NOBODY'S FOOL
« Reply #8 on: December 03, 2006, 03:50:13 AM »
Good , prompt answers from some of the most experienced in the sport.
Even they all have a little different view of the same objective with all the information complementing the other.
The additional plus is that good answers here will also help those that might have been afraid to ask or otherwise mislead.
That is how it should be done.
I think I like it. :-D
Offline Dean Los Angeles
« Reply #9 on: December 03, 2006, 12:57:29 PM »
Jack! A full sentence with proper sentence structure, and totally positive!
Offline bbb
  • Aerodynamically Challenged
  • JorNic Motorsports
    • JorNic Motorsports, Charlottesville, Va.
« Reply #10 on: December 03, 2006, 08:48:37 PM »
he's off his meds again.
