Author Topic: Jessiechop, bike tech question  (Read 5003 times)
Offline Truckedup
« on: April 04, 2017, 09:12:19 AM »
 I built the dual engine Triumph you see in the photo....It will be coming to Loring in July.....The engines are linked by #428 duplex roller chain (like a Harley primary chain) ...the chains and clutch are enclosed by the sheet metal cover to comply with the rule to prevent rider entanglement with open primary drives...My rider fabricated the cover from 16 gauge steel ,.062 inch.It's securely mount with eight 1/4 and 5/16 bolts It's open on the bottom because I feel it better for a potential broken chain to exit easily rather than jam and possibly lock the rear wheel....
  Is this cover adequate for the rules ? Thanks
  This is what's under the cover....Been tested on the rural back roads  :evil: and next week the bike goes on the chassis dyno for tuning and durability tests.
« Last Edit: April 04, 2017, 09:19:22 AM by Truckedup »
Jessechop
Re: Jessiechop, bike tech question
« Reply #1 on: April 04, 2017, 12:16:55 PM »
That should be fine. I see no issues with it.
Offline 72tx340
  • Hooked on speed
« Reply #2 on: April 10, 2017, 08:11:43 PM »
As a triumph owner myself I must say that is SOOOOOOOO nice cant wait to see that bike run!
Offline Truckedup
« Reply #3 on: April 15, 2017, 07:23:38 AM »
 Thanks,  The double engine bike goes on the dyno May 4th.....If it doesn't blow up you will see it at Loring in July... My 650 MPG Triumph held the record at Loring for a year at 128.2 MPH, but the dreaded BSA took the record back....  However it's likely I won't be there ,just my rider and the bikes...
   The 650 MPG bike had a few changes and now looks like this....
« Reply #4 on: April 15, 2017, 05:52:52 PM »
Six Hundred and fifty miles per gallon is significant!
Offline Truckedup
« Reply #5 on: April 17, 2017, 06:29:15 AM »
  650cc modified production pushrod gas   :-D
Offline panic
    • My tech papers
« Reply #6 on: May 08, 2017, 03:58:23 PM »
How do you have the engines phased: alike, or #1 TDC ignition = #2 TDC overlap?
Offline Frank06
Re:
« Reply #7 on: May 08, 2017, 10:36:12 PM »
...and did you get to the Dyno?
E-Racer
Offline Truckedup
« Reply #8 on: May 14, 2017, 06:54:24 AM »
 Left front cylinder fires  degrees before the left rear cylinder...So it's like a big 360 degree twin so to speak...it's actually fairly smooth running, not radically tuned and idles like a stock Triumph at 900 rpm
  On the dyno it made 93 HP @ 6000 rpm...and 95 HP at 7200 rpm....85 ft lbs torque@ 5400  rpm.....As suggested by Panic above, the exhaust pipes are too long causing the power curve to flatten out but the engines are still willing to rev freely to 7500 rpm.. I shortened them 4 inches, see how it goes at the track...50 RWHP is a decent number for a modified Triumph 650 engine with a more or less stock head with a careful valve job
  The many runs on the dyno also tested the primary drive for durability...No problems
Offline jacksoni
« Reply #9 on: May 14, 2017, 01:33:34 PM »
Just playing with Pipemax. On the two engine bike are there 4 individual pipes or collected into 1 with a megaphone as on your single? Quickie Pipemax says 31-34" primary so Panic's cut 4" off suggestion is on the money for primary. If they are collected it looks like the pipe length on the front engine would be much longer than on the rear.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
