Author Topic: 200MPH Vintage Class Bike Build  (Read 77524 times)
Offline astek
    • Alp Racing & Design
Re: 200MPH Vintage Class Bike Build
« Reply #75 on: January 25, 2017, 12:50:57 PM »
What alloy and thickness are you using for your body panels?
manta22, .063" 3003
Offline RidgeRunner
« Reply #76 on: January 25, 2017, 02:05:39 PM »
    Nice work, I'm following with great interest.   :cheers:
    What planishing methods/tooling are you using?
Offline astek
« Reply #77 on: January 25, 2017, 10:12:48 PM »
Thanks Ed,  I do the rough shaping on the stump with the wood mallet, I use the slapper to make it smoother and then the wheeling machine. In some areas I use the shrinker.
Offline panic
    • My tech papers
« Reply #78 on: January 26, 2017, 09:09:29 AM »
Based on the top speed, you're going to need a really tall 1st gear to have any RPM recovery. I'm not sure of how different the pre-unit vs. unit transmission gears are, but to get the 3-4 shift loss below 16% you'll need the close-ratio 24/22 high gear set.
Offline Frank06
« Reply #79 on: January 26, 2017, 09:16:23 AM »
Excuse my ignorance, but which event(s) are you planning to run at?
thanks,
Frank
E-Racer
Offline astek
« Reply #80 on: January 26, 2017, 02:25:10 PM »
Good point panic,, the std box ratio gap between 3 to 4 is more than the cr,  3rd gear reduction is 1.19:1 for the std.
The close ratio has less reduction and is only 1.09:1 for the 3rd  gear but it starts with first gear 1.69:1 which will be tough to take off whereasthe std box first gear has a 2.44:1 reduction.
The wide ratio first is 2.91:1 but that gap between 3 and 4 is huge. wr 3rd is 1.425:1
The 5 speed later unit has a larger gap between  4th and 5th than the close ratio 4 speed (unit and pre unit 4 speeds have the same ratios)
I have both gearboxes.
thanks,
Frank
The plan is to run SCTA, AMA and FIM
« Last Edit: January 26, 2017, 02:27:52 PM by astek »
Offline thefrenchowl
« Reply #81 on: January 27, 2017, 02:43:19 AM »
Hi,
Panic: Based on the top speed, you're going to need a really tall 1st gear to have any RPM recovery
Wouldn't the ratios be more dependant on where the max torque's revs are?
Patrick
Offline bones
« Reply #82 on: January 30, 2017, 05:12:58 AM »
Hi astek
Your build is looking REAL NICE
Have you looked at TT Industries in New Zealand for a gearbox?
I don't know if they do a Triumph gearbox, but they do very nice Norton type gearboxes.  4-5 and 6 speed.
A mate has a 5 speed behind a BMW turned sideways   I will know how it works at the end of the month
    Bones
Offline astek
« Reply #83 on: January 30, 2017, 01:47:45 PM »
Hi astek
    Bones
Thanks Bones, I will be using the p/u Triumph gb on this project (no time to change the frame members at this point) but I am looking for alternatives for my other builds. Please let us know how you like the TT Ind. box.
Offline makr
  • I make my own rules
« Reply #84 on: February 10, 2017, 10:18:02 PM »
Looking good Alp! Can't wait to see this one.
Ride fast, safety last.
https://speedofcheeseracing.com/
Offline astek
« Reply #85 on: February 16, 2017, 01:45:48 PM »
Thanks makr,   it would be great if we can have a photo shoot with the "Alpha" and the "T200" together on the salt.
Working full speed on the body, here is the chin area, I had to make each side out of three pieces.
Offline astek
« Reply #86 on: February 23, 2017, 01:55:23 PM »
Making progress
Offline MattGuzzetta
« Reply #87 on: February 23, 2017, 05:39:24 PM »
My goodness, that is some great work....question, are you gas welding the aluminum?  In the 60's I was able to do work with a master metal shaper, Jack Sutton, and Englishman who came from the aircraft industry and was a amazing guy who used to make his car and aircraft panels with a large cast iron wheel.  He would make his welding rod by making thin strips from the panel he was making and gas welded/brazed the material by dipping the heated section of the strip in borax and then just melted it together, then ran it through the wheel to make the panels and the "weld" work together.  I did try it a couple of times, but it aint easy gas welding aluminum!  :-D
Congrats on your work, very nice!
Matt Guzzetta
Offline astek
« Reply #88 on: February 24, 2017, 12:33:51 AM »
Matt Guzzetta
Thanks Matt,
Yes I'm gas welding aluminum panels, sometimes I tig weld but I prefer gas welding.
Offline sofadriver
« Reply #89 on: February 24, 2017, 01:26:19 AM »
Alp, what about engine cooling?
Mike in Tacoma
Bike #833
