Author Topic: 200MPH Vintage Class Bike Build  (Read 77411 times)
Offline thefrenchowl
Re: 200MPH Vintage Class Bike Build
« Reply #120 on: March 22, 2017, 06:07:44 PM »
Lambky has the highest vintage record,
3000cc SCS-VBF, at 191.303 in Sept 2010
Patrick
Offline Vinsky
« Reply #121 on: March 23, 2017, 01:08:26 AM »
What year was the vintage class started?  There are some vintage bikes that have records over 200, just not in vintage class.
« Reply #122 on: March 23, 2017, 10:08:09 AM »
Dave Matson probably has the fastest Vintage class qualified motorcycle... his records were set in 1988, before vintage class, 210 open and 225 faired.... not bad for an old Vincent.  I am sure when a modern motorcycle beats his records, they will be moved to vintage class by the SCTA.
Offline astek
    • Alp Racing & Design
« Reply #123 on: March 23, 2017, 01:13:47 PM »
Dave Matson ran while Vintage class was present,  but he ended up running in the unlimited classes, he also ran in the vintage class.
Vintage class has its own rules. I'm running my P class Triumph engine as well, it looks almost the same as my V engine but it is totally different. I cannot run certain aftermarket parts and electronics other than for documentation purposes.
The picture shows Dave Matson running in the same "APS-VF" vintage class that I will run, except my engine displacement is 650cc.
Offline bones
« Reply #124 on: March 24, 2017, 02:50:13 AM »
Hi Alp
   My mate with the TT Industries gearbox is pleased with it.
He only did 2 runs at Gairdner but has had it on the dyno a couple of times.
The BMW is making 100hp
So far so good
What Bonneville meetings will you be at this year?
I will have my naked Bussa at BMST and WoS--- see you in impound  :-)
   Bones
Offline astek
« Reply #125 on: March 25, 2017, 01:17:15 AM »
Hi Alp
So far so good
   Bones
Bones,
That sounds good, we will be at Speedweek first but planning to be at the BMST too. Looking forward to seeing you in impound :)
Offline astek
« Reply #126 on: April 03, 2017, 06:39:35 PM »
Making the oil and fuel tanks,
Offline astek
« Reply #127 on: April 15, 2017, 09:55:02 PM »
Making the primary cover and chain guards/rails.
Offline sofadriver
« Reply #128 on: April 16, 2017, 02:35:01 AM »
Looks great Alp.
So what all had to be done to turn the cylinder/ head around like that?
Mike in Tacoma
Bike #833
Offline astek
« Reply #129 on: April 16, 2017, 03:12:09 AM »
Looks great Alp.
Thank you sofadriver,
Reversing the head is a common mod for Triumphs (which I'm not a fan of for stock bikes), the 8 bolt head pattern is not directional, you just need to change the camshafts.
I did this to improve the exhaust port/pipe geometry. Redesigning the ironhead took me weeks.
Offline panic
    • My tech papers
« Reply #130 on: May 08, 2017, 04:00:49 PM »
The cube root relationship is a bit conservative, since the small corrections for rolling resistance and weight don't scale as rapidly.
Offline astek
« Reply #131 on: May 14, 2017, 06:59:43 PM »
Thanks Panic,
The body is at the paint shop, doing the lettering and sponsors names.
Offline astek
« Reply #132 on: May 23, 2017, 04:01:59 PM »
Frame pictures after nickel plating:
Offline ggl205
« Reply #133 on: May 23, 2017, 05:00:38 PM »
I love bright nickel!
Offline astek
« Reply #134 on: June 16, 2017, 09:44:32 PM »
Engine/gearbox ready to slide into the frame.
