Author Topic: 200MPH Vintage Class Bike Build  (Read 77488 times)
Offline astek
    • Alp Racing & Design
Re: 200MPH Vintage Class Bike Build
« Reply #105 on: March 19, 2017, 03:40:52 PM »
Will you be running SCTA or BMST?
Beautiful body.   :cheers:
Thanks Don,
I'm going to run it first at the SCTA and later the plan is to run it FIM and AMA.
Offline thefrenchowl
« Reply #106 on: March 19, 2017, 04:54:23 PM »
I see, Astek,
The "beak" rotates with the forks, clever...
Reminds me of the "becco d'uccello" on 50's road racing Guzzi's fairings!!!
I'm still a bit worried about the rule that says that the perimeter of the front fender can't be more than 1"75 away from the tyre thread (rule 7.G.11, APS)
Patrick
« Reply #107 on: March 19, 2017, 05:21:52 PM »
Here's a different approach with the arms and legs visible (and hopefully not much else) . . .
« Reply #108 on: March 19, 2017, 05:23:04 PM »
I can see Freud riding this.
Offline Old Scrambler
  • Going Fast - Slowly
« Reply #109 on: March 19, 2017, 08:50:59 PM »
I believe the rule applies to the leading edge of the fender.............
Offline astek
« Reply #110 on: March 21, 2017, 03:58:18 AM »
frontal
Offline stay`tee
« Reply #111 on: March 21, 2017, 07:22:50 AM »
 "Porthole" vision is tunnel vision,, Aero will not be affected with a full screen following the line of the aluminium bodywork that you have,, the most important thing with a full screen is that you will have hundred percent orientation as to where you are "on course"  :-)
Offline NathanStewart
« Reply #112 on: March 21, 2017, 03:30:53 PM »
You've not seen Alp ride his bike before.  :wink:
El Mirage 200 MPH Club Member
Offline stay`tee
« Reply #113 on: March 21, 2017, 09:12:37 PM »
This topic is headed "200MPH" Vintage Class Bike Build,, to make such a statement shows that the boyz have aspirations of achieving their stated speed, I wish 'em luck, but I also want to see them achieve it "Safely",,
No, I have not seen Alp ride his bike at that speed, actually how fast has he done  :?
Offline Calkins
  • On Any Sunday
    • Facebook
« Reply #114 on: March 21, 2017, 09:27:57 PM »
Take a peek...
http://www.alpracingdesign.com/vintage-triumph-pre-unit-engine-records
Offline Koncretekid
« Reply #115 on: March 21, 2017, 10:25:54 PM »
X-ray vision??? :-D
Tom check this out,
[/quote]
I have (had) a full windshield, although I do look thru my triples, and have still taken out two side markers.  But of course, your eyes are 25 years younger than mine :-o
Offline stay`tee
« Reply #116 on: March 22, 2017, 07:56:49 AM »
175.625mph, is impressive on a 650 Triumph, but be assured, 200mph is a loooooong way from 175, especially when it comes to handling and aerodynamics  :roll:,,
I have experienced various wind conditions at 175mph, no problem at all, but the same conditions at 200 certinally got my attention real quick  :-D,,
As this bike gets faster, I guarantee we will see the windscreen get larger "real quick"  :wink:, and I hope that happens before we see that beautiful alley work all messed up,,
Nuff said, I'm outta here  :-)
Offline astek
« Reply #117 on: March 22, 2017, 01:16:25 PM »
A race bike to me is never done, it's an ongoing process. Stay`tee is correct I can make the window larger or add a second one on the other side if I need to. The frame, the body, the engine is going to be all new (designed/built) so I will figure out many things as I go but I hope I will be the first to get into the 200mph club with a pre 56 vintage class motorcycle.
Offline Calkins
  • On Any Sunday
    • Facebook
« Reply #118 on: March 22, 2017, 02:10:34 PM »
I believe Max has already done that with his Vincent streamliner.
Offline astek
« Reply #119 on: March 22, 2017, 05:05:48 PM »
I looked in the books (SCTA/AMA), couldn't find any record over 200mph in any vintage motorcycle class, I could be wrong.
