Author Topic: Schimmer and Son "I" class fuel lakester:  (Read 161524 times)
Re: Schimmer and Son "I" class fuel lakester:
« Reply #180 on: November 15, 2017, 03:00:23 PM »
Stainless, who's air shift system did you use or did you make it yourself? Duke and I are pretty much mechanical guys so we always start out that way. What Duke has done so far is pretty nice, the shifting shaft goes through a oilite self aligning bearing mounted in the fire wall and then the shaft from the shift lever will have a small U joint in to provide enough flex to keep the shafts aligned. We will provide pics as progress is made. I have been off deer hunting in AZ for the last two weeks to my rear axle modification is at a halt.
« Reply #181 on: November 15, 2017, 11:57:53 PM »
We made it... they are really easy and reliable.  We shift up and down with one button, one switch, one solenoid, one air cylinder actuator and a couple feet of plastic line from the storage bottle.
Offline Duke
« Reply #182 on: November 16, 2017, 10:20:37 AM »
Stainless, I did briefly consider it, but like my dad said we are both very mechanical people and this was ultimately what I felt more comfortable with.  I also have a bit of experience working on vintage mid-engined sports racer and open wheel  cars which use a very similar linkage to what we will have.  The linkages are very reliable in those applications and they do many more shifts than we will ever do.  It also keeps it a bit more simple...and I like simple.
Duke Schimmer
"Simplify and add lightness."
« Reply #183 on: December 18, 2017, 02:08:56 PM »
Just a little update on what we are doing to our lakester right now. We decided that we should have a stronger bearing on the side of the rear axle that has the panard rod as we do not feel that a single ball bearing is satisfactory when an axial (thrust) load is applied off set to the bearings axis. A single row ball bearing does not carry this load well so we have gone to a double row angular contact bearing. To accommodate this wider bearing we needed to lengthen the diameter on the axle that the bearing mounts by about 1 inch. Duke did an over lay weld and I just finished machining it. Came out pretty good the run out is +or- .001. Next the axle and assorted steel parts are off to the electroless nickel platers to get a good rust preventative coating.
Lots of things to do, just have to do something every day.
« Reply #184 on: December 18, 2017, 02:11:15 PM »
I meant to show Duke's overlay welding also.
« Reply #185 on: December 18, 2017, 02:34:14 PM »
That is a really nice job on the overlay. He has a really good hand and an eye to match.  :cheers: :cheers: :cheers:
« Reply #186 on: March 23, 2018, 01:52:49 PM »
A quick update on the progress of the Schimmer and Son IF/L. We have taken the engine and all of the new race parts to Engine Dynamics to be assembled. Should be back early June hopefully with some extra HPs included! We had all of the aluminum parts for the rear axle assembly black anodized and the axle itself has be electroless nickel plated, looks great! We are waiting on one bearing then we will assemble the axle and install in chassis. Waiting for feedback from Burns Stainless regarding a new header design, once we have it I will turn Duke loose with a bunch of stainless tubing and we will have a new stainless exhaust system. We have drawings out to the water jet shop for our new 17 inch wheel center fabrication so should have them ready for welding soon. We installed a new 3 gallon fuel cell to replace the 4 gallon cell we originally had, it gives us more room around the axle for the new panard rod installation we are doing. I am working on drawings for the mounting of the airfoils over the front and rear axles and have started to make the forming bucks for the ribs. Plenty to do but keeping at it every day gets it done. As we make some "seeable" progress I will attach pictures.
Rex and Duke
« Reply #187 on: April 22, 2018, 11:10:00 PM »
Making progress on the new wheel/tire combo. Got the centers for the new rear 17 inch wheels back from water jet cutting and then machined to be a .01 to .015 shrink fit in to rims. The team welding specialist (Duke) is now welding the centers into the rims. Ordering new tires next week,hope that the big reduction in width and a little increase in diameter will work out as we are hoping!
« Reply #188 on: April 22, 2018, 11:35:00 PM »
Good looking wheels Rex with really pretty welding!  :cheers: :cheers: :cheers:
« Reply #189 on: August 10, 2018, 02:15:24 PM »
Well while everyone is at the salt Duke and I have been hammering on our little lakester to get ready for the World of Speed meet. Quick pic of the new headers that Duke is almost done with.
Offline ggl205
« Reply #190 on: August 10, 2018, 03:08:10 PM »
Beautiful and well thought out work, you guys. That little tank is going to rock in September. Wish I was there to see it.
« Last Edit: August 11, 2018, 09:37:39 AM by ggl205 »
« Reply #191 on: August 10, 2018, 05:35:26 PM »
Rex, just awesome craftmanship.
Very impressive. Wish you guys all the best.
« Reply #192 on: September 01, 2018, 11:54:59 AM »
WOS is getting close and Duke and I have been hammering on getting the car ready. Started the engine last Saturday, man does it sound stout! I have attached some pics showing our new front spindle fairing and new, narrower front tires, also a pic showing the new rear tires that are 1 1/2 inch narrower than the old ones plus 1 1/2 inches taller which gets us a little more ground clearance. You can also see the axle fairing, not quite as much as I would like but that is for next year. Still may do some front axle fairing if I can get the trailer squared away next week. Got the chassis squared and corner weights done and re did the sealing on the air box to the scoop. Lots of things but all good. Working with Kinsler on injection set up for new engine and possible "soda pop" use. Duke is getting his "office" squared away, new shifter linkage, better linkage to brake master cylinder, getting belts installed etc.
12 days till I leave better get back to it!!
« Reply #193 on: September 01, 2018, 11:56:57 AM »
These pics did not get on previous post.
« Reply #194 on: September 01, 2018, 03:06:47 PM »
I really dig the unified and measured approach you've taken with making this lakester your own.  Best of luck this year.
Save a little salt for me - I'm looking at October.
