Doesn't take long looking at Woody's chart on a "standard" P38 tank to see that what you do with the wheel/tires and the axles have a lot bigger effect than anything you do with the actual tank body. Reducing the drag of the axles, which I assume are a standard round section, can be reduced by over 50% with simple aero fairing, I know this works as we faired the rear axle of Steve Nelson's lakester and picked up 6 mph with no other changes. The selection of the wheel/tire combination is very important, check Sparky's beautiful front wheels and top fuel tires to see a good approach. Sparky also likes to run short rear tires, again trying to reduce the frontal area of the tires. It is the attention to detail on a lakester that makes them fast, no junk (spindles, shocks,springs,radius rods etc) hanging out in the breeze. Smooth is fast.
