OJ, let's start again, what tank do you have to work with, what motor do you plan to run, are you set on a tank or do you just want to build a lakester
Sounds like he's talking about one of those 1/2 460 engines. My advice is the same what ever tank you use, the more crap you stick out of it the worse it gets. You're starting out with a clean bullet, don't f^*k it up! Get down inside the thing & make the windshield part of the nose. Don't use a fat front tire, there is no turn one in LSR & you don't need a 5 strut Indy suspension with all that extra drag either. Sid.
Look at Markly's tank if your set on a P38. Worked then and would work now.
