Author Topic: Nebulous Theorem 3.5 Streamliner  (Read 5499 times)
Offline turborick
  • Go as fast as we can with as little as we can
    • http://www.bonnevillestreamliner.com
« on: September 20, 2016, 02:07:38 PM »
Our last test run @ Speedweek went to the 4 mile still on low boost. Hope for smoother salt next year.
https://www.youtube.com/watch?v=dfUwvupF6h4&
Rick Yacoucci
The new Nebulous Theorem 3.5 #788
Re: Nebulous Theorem 3.5 Streamliner
« Reply #1 on: September 20, 2016, 02:45:39 PM »
Boy does that thing go straight! Very impressive for such a rough track. Looks like you had you waste gate set at 183 kpa (26 psia) so your boost is pretty conservative and which means a lot more to come!! Thanks for sharing Rick.
« Reply #2 on: September 20, 2016, 03:05:26 PM »
 :cheers: :cheers: :cheers:
Offline TrickyDicky
« Reply #3 on: September 20, 2016, 03:52:36 PM »
Great to be able to see the instruments so clearly.
Is that the same body/chassis as Nebulous Theorem 3 with a bigger engine?  3.5 litre?  Not much comes up from an Internet search.  Thanks for any details available.
Offline turborick
« Reply #4 on: September 20, 2016, 03:57:26 PM »
Thanks Rex the camera really doesn't show how rough it really was. I had vision problems because of the roughness.
Yea low boost 180 kpa which is really only 14 psi when you subtract the barometric pressure.
We will be running about 300kpa when we turn it up
Rick Yacoucci
Offline turborick
« Reply #5 on: September 20, 2016, 04:01:02 PM »
Same body, new chassis. We hope to build a new body soon. The engine is a 4.2 litre destroked chevy
Rick Yacoucci
Offline TrickyDicky
« Reply #6 on: September 20, 2016, 04:33:50 PM »
Thanks Rick.  Can you build a better body??
Offline turborick
« Reply #7 on: September 20, 2016, 04:59:50 PM »
We will continue testing with this body and see what Jack wants to do..... at the very least it will be lighter
Rick Yacoucci
« Reply #8 on: September 20, 2016, 08:13:32 PM »
Rex is right. The car does run straight.
Awesome to see that video.
Thanks Rick. :cheers: :cheers: :cheers:
