Author Topic: Step Pan on FALT or GALT  (Read 9373 times)
Offline DKrause615
« on: September 01, 2016, 03:15:08 PM »
I am considering the addition of a "step pan" on my C/FALT.  Can anyone speak to the effectiveness of this modification.  Most cars run a very low front air dam which would vastly reduce the amount of air flowing under a car anyway.
Offline Bob Drury
Re: Step Pan on FALT or GALT
« Reply #1 on: September 01, 2016, 05:21:52 PM »
  You have pretty much explained it to Yourself.  The rule was written before the front Air Dam's were made legal in the early 2000's.  On a comp coupe where underside strakes are allowed it might be a different matter (having a full belly pan).
        Bob Drury
Bob Drury
Offline ronaldbrooks
« Reply #2 on: October 03, 2017, 08:33:36 AM »
Yes, I completely agree with Bob :cheers:
I like cars and everything that is related with it! That is a real passion for me
Offline Bratfink
« Reply #3 on: October 04, 2017, 09:21:31 AM »
Agreed. There will be a small drag improvement even with the airdam, just because you are cleaning up the underside and controlling flow. But a large airdam will really reduce the flat underbody shields effect to a point where you probably wouldn't notice any benefit. You might see more lift effect depending on how you do it. But it does risk getting you into pitch sensitive issues where a small increase in ride height results in a large swing in front downforce.
Offline Jim Phelps
« Reply #4 on: November 01, 2017, 10:48:42 PM »
What is a "step pan"?  Is this the same as a belly pan?
Offline jacksoni
« Reply #5 on: November 02, 2017, 07:10:21 AM »
Rule 4.G and  4.EE
You do have a rule book don't you? :wink:
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline Jim Phelps
« Reply #6 on: November 03, 2017, 09:35:28 PM »
Thanks.  Yes, I have a rule book.  I'll look it up.
