Author Topic: Frame Issue  (Read 31217 times)
Offline Pippi2
  • "Do or do not.... there is no try"
Re: Frame Issue
« Reply #60 on: May 23, 2017, 10:36:58 PM »
…. you owe me nothing but the promise that you will go fast and stop safe.
See you on the Salt.
Offline 56KHK
Re: Frame Issue
« Reply #61 on: May 29, 2017, 05:20:12 AM »
Only if you point me in the right direction!
Jim
Offline JimL
Re: Frame Issue
« Reply #62 on: May 30, 2017, 01:00:40 AM »
don't forget....you cannot add 10% of the stock wheelbase to the swingarm.  You can only add enough that the rearmost wheel position (in the chain adjustment range) is now 10% over the advertised wheelbase (which is usually with the wheel adjusted all the way forward.
It means you only get about 5% or so (depending on the length of the axle slot).
J
