Author Topic: HP Needed for Speed...AT A DISTANCE ?  (Read 9485 times)
Offline CLS
« on: August 05, 2016, 04:58:22 PM »
Does anyone know how to calculate the distance you reach a certain speed?  I am heading out for my first time this year, trying for the 150 club.  I've run 1/2 and full mile events on pavement, used the 'HP needed for speed' sheet that says my theoretical top speed...but can I hit 155 on salt in two miles?  In another event (Big Bend Open Road) the car reached it's tech (168 mph) on pavement but I did not measure how long it took.  Thanks, appreciate any assistance.
Offline bearingburner
Re: HP Needed for Speed...AT A DISTANCE ?
« Reply #1 on: August 05, 2016, 07:58:52 PM »
A lot will depend on rear end gear. With too high a number gear you can be wound out tight before the first mile. To low a number your engine may not be able to pull it in high gear.
Offline 55chevr
« Reply #2 on: August 05, 2016, 08:38:51 PM »
what was top speed achieved on paved mile?
JOE
Offline CLS
« Reply #3 on: August 05, 2016, 10:25:28 PM »
Thanks guys.  Top speed on a paved mile with a passenger (230 lbs) was 143.  Obviously no passenger on this run.  At the wheel it is 410 hp and tq.  Here's the "final drive" (trans gear X axle ratio) for the 6 speed w/3.92:
2.97 11.64
2.10 8.23
1.46 5.72
1.00 3.92
0.74 2.90
0.50 1.96
4000 lb. Challenger. 155 on the salt in 2 miles?
Thanks!
« Reply #4 on: August 05, 2016, 11:28:59 PM »
You'll know in September...  :-o
Actually if you car is capable of doing 155 at 6000 ft+ DA then you should be OK, there is less traction than pavement, but you have 2 miles to get there and then another quarter to be timed.  The big difference is no hard launch and altitude to deal with.
Good luck with your quest, see you at the WoS.  8-)
« Reply #5 on: August 05, 2016, 11:57:59 PM »
Choice of tire is huge on the salt. You don't run a wide ice tire & you need to approach the salt the same. I think there's two people on the forum that think the opposite is true so expect a rebuttal from them. :evil:
Offline trimmers
  • Jeff in Boise
« Reply #6 on: August 06, 2016, 07:23:34 AM »
Check out the formulas here:
http://purplesagetradingpost.com/sumner/bvillecar/bville-spreadsheet-index.html#Horse%20Power%20Needed
You'll probably need to know your Cd and frontal area to get a good answer.  Weight counts too, as although it sounds like you've got plenty of room, you run out of it PDQ.
I've done it, and I can tell you that it ain't as easy as it sounds!  The DA could be as high as 7000' feet, so I think if you're running a newer car with EFI and an ECU, you'll have a better shot.   When my kid and I made it (in a daily driver 350Z, with only a couple minor mods), there were a lot of pretty serious cars there that couldn't get the job done.
On one of my runs, I missed a shift (got 5th instead of 3rd!) and it cost me about 4 or 5MPH.  So, there not much wiggle room.
The bottom line is that they don't call it the "Big, white dyno" for nothin'!  Just show up and run to get your final answer.
------------- 1 of just 3 in all 3  -------------
USFRA 130 MPH Club 09/18/2008 136.757
USFRA 150 MPH Club 09/17/2009 152.162
Bonneville 200 MPH Club 09/15/2019 218.600
Best Run: 253.080 MPH 09/14/2019 #6556
Offline nrhs sales
« Reply #7 on: September 09, 2016, 04:39:59 PM »
if your car is normally aspirated you will lose somewhere between 10-15% of your power if it is a hot day at Bonneville compared to sea level so I have a feeling it will be be close to whether or not your car can hit 150 at the salt.
Offline CLS
« Reply #8 on: September 11, 2016, 12:41:02 AM »
Thanks everyone, first two passes were at 156...
Offline rouse
  • Impound is the place to be
« Reply #9 on: September 11, 2016, 06:10:13 PM »
If the aerodynamic of you car is high and a lot of frontal area, you may run fast at Bonneville than you would at sea level.
Kind of works like this, you lose 10-12% HP and also lose 12 -14% drag due to altitude. Net results a little fast.
Rouse
Johnnie Rouse
Offline Interested Observer
« Reply #10 on: September 11, 2016, 06:46:24 PM »
Since the power potential for an NA engine is proportional to the air density, and the aerodynamic drag is also proportional to the air density, going between two elevations should be a wash.  Where do you get your numbers?
Offline rouse
« Reply #11 on: September 12, 2016, 08:35:39 AM »
Without getting into a protracted discussion as to why, the math will do that for you, you gain slightly more on aerodynamics than you lose on HP. That's just how it is, NA sure wont have the gains that supper charging has, but there is some.
Rouse
Johnnie Rouse
