Author Topic: Roll Bar Padding  (Read 14190 times)
Offline bearingburner
Roll Bar Padding
« on: April 29, 2016, 09:01:02 AM »
What is the best way to form SFI roll bar padding to the bends in the roll bar?
Re: Roll Bar Padding
« Reply #1 on: April 29, 2016, 09:52:09 AM »
Buy the round stuff & zip tie it on so you can take it out if you need to.
Jessechop
« Reply #2 on: April 29, 2016, 12:22:55 PM »
Do you have a link or part #? The only sfi stuff I henge found is just as hard as the cage itself
Offline Ron Gibson
« Reply #3 on: April 29, 2016, 01:18:04 PM »
It will conform with brute force and a BFH. Kidding, It will bend to follow the bars.
Ron
« Reply #4 on: April 29, 2016, 01:41:14 PM »
Try Jaz products.
Offline Joe Timney
    • Delaware Chassis Works
« Reply #5 on: April 29, 2016, 02:09:21 PM »
Use the 1/2" Jaz and a heat gun to soften it up. I can drop ship some to you from Behrent's if you need it.
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
« Reply #7 on: April 29, 2016, 04:08:09 PM »
Yep, it's job is to make sure the roll bar doesn't crack the helmet, it does feel pretty hard but it spreads the impact load over the surface without bottoming out
« Reply #8 on: April 29, 2016, 05:27:22 PM »
I got some from Jaz. Their Tech. Services had no clue on how to bend it. Tried a heat gun but the padding broke when I tried to bend 90* it broke. Maybe need to heat more.
« Reply #9 on: April 29, 2016, 07:04:06 PM »
 :? If you have the formed stuff & you need to transition a 90* junction in the tubing, just cut it to length! Your helmet can't fit into the corner of the junction, it's round. :-D Or am I totally not getting what you're talking about? :|
Offline ronnieroadster
« Reply #10 on: April 29, 2016, 07:09:18 PM »
Using the Jaz brand I had no trouble bending the padding into the cage radius. More heat should do it plus slow and easy.
« Reply #11 on: May 12, 2016, 12:35:56 PM »
Learned something again, Joe never thought about warming it up with the heat gun. Thanks,
« Reply #12 on: May 12, 2016, 12:47:20 PM »
My problem may be that the padding is 4-5 years old. Always stored in box in basement but may have
"aged".
« Reply #13 on: October 01, 2016, 09:34:49 PM »
Talking to the founder of Orange Aid a few years back, whos son is a neurosurgon and he let me in on a secret which I have posted here before. A standard pine 2x4 will pass the SFI test for rollbar/interior padding. In other words it is junk. I watched Eric from Alaska try and bend some JAZ stuff that had been sitting in the sun all day and it broke like a 3 day old breadstick. ISP, and others are at least working with better options. I strongly feel there is a lot of room for improvement here with the technologies we have today. Things like Zoombang that are energy dissipating and such.
Offline panic
    • My tech papers
« Reply #14 on: October 07, 2016, 11:17:03 AM »
Helmet foam
