Author Topic: Paint removal  (Read 2908 times)
Paint removal
« on: February 23, 2016, 04:49:59 PM »
The serial number alum. sticker has been painted over on this trailer.  I need to gently try to remove the paint with out harming the 40 year old alum sticker .  I have no idea what kind of paint was used. Suggestions please---I need to be able to read the serial number to get a title and plates!
Offline Speed Limit 1000
Re: Paint removal
« Reply #1 on: February 23, 2016, 04:58:07 PM »
Home Depot
Citristrip Model # ECG73807 Internet # 100164441 Store SKU # 323433 17 oz. Safer Paint and Varnish Stripper
Offline Polyhead
Re: Paint removal
« Reply #2 on: February 23, 2016, 08:36:13 PM »
Brake fluid.
Ben 'Polyhead' Smith
  KE7GAL
Re: Paint removal
« Reply #3 on: February 24, 2016, 12:33:15 AM »
Thanks guys, I thought about brake fluid.  I thought it might be too aggressive, I will try some on my other trailer's tag as a test. in the AM
Offline Polyhead
Re: Paint removal
« Reply #4 on: February 24, 2016, 08:18:31 AM »
Good plan.  Just depends on what kind of plastic is used as the top layer of that sticker.  Hard to believe it wasn't some sort of stamped metal.
  KE7GAL
Re: Paint removal
« Reply #5 on: February 24, 2016, 11:30:45 AM »
Those plastic stick on tags are common on trailers & are the same as used on vehicles. What ever you use don't wipe it or you will end up with a blank tag. Let it soak & dab it gently.
Re: Paint removal
« Reply #6 on: February 24, 2016, 11:47:57 AM »
Right on Sid  this has an aluminized layer that is indented/stamped    maybe typed with and old timey striker keys typewriter
