Yes. AN fittings don't require double flares since they use a ferrule. AN fittings are all 37 degree flare angles, not 45 degrees like JIC or SAE, so you can't intermix those types with AN.
AN fittings and aluminum tubing is commonly used for fuel and oil lines. They are reliable and simple to assemble. Parker makes a line of nice tools- tubing cutters, tubing benders, flaring tools, and beading tools. Good stuff can sometimes be found in aircraft surplus stores or eBay.
For AN to NPT adapters, check out Speedway Motors, Aircraft Spruce, or Pegasus Racing.
Regards, Neil Tucson, AZ
