Author Topic: G/F class lakester in Wichita, Kansas  (Read 220711 times)
Re: G/F class lakester in Wichita, Kansas
« Reply #195 on: April 21, 2017, 11:26:19 PM »
That's R28,000 in our money. Big bill even for you guys. :-D
« Reply #196 on: April 22, 2017, 12:04:48 AM »
No worries John, running the 1 liter at SpeedWeek.... will swap the big motor in for our fun at WoS.
Offline ggl205
« Reply #197 on: April 22, 2017, 07:33:25 AM »
Excellent!
« Reply #198 on: April 25, 2017, 01:57:54 PM »
Stainless,
Is your 1000 cc motor going to be on some N02? The record in I/FL is high enough!!
« Reply #199 on: April 25, 2017, 10:13:10 PM »
Stainless,
No Rex, it's blown... we will leave the I/FL record alone until you break it... and we have welcomed you and your son to the club.  8-)
« Reply #200 on: April 26, 2017, 02:00:04 PM »
Stainless,
You are all heart! Is you blown motor going to be gas or fuel? My son and I are thinking about putting a hair dryer on our "good" motor to run I/BF next year as that record is a little "softer" than your I/F record. With our constant flow injection and methanol we wouldn't need a charge cooler if we keep the boost below 12 psi so it could be a relatively easy mod, but as you so well know NOTHING is easy at the salt. You have so much experience with so many combinations and we are truly "babes in the woods" there.
John, sorry for pirating you build now back to your great G lakester build.
Offline ggl205
« Reply #201 on: April 26, 2017, 03:00:02 PM »
"John, sorry for pirating you build now back to your great G lakester build."
Rex, not a problem at this end. Poor Stainless, he is being challenged in I and G class but lots of fun to be had by all.
« Reply #202 on: April 26, 2017, 07:04:40 PM »
Poor Stainless?
I counted 9 Lakester records in the current Rule Book.
I guess he does (and has) known what he's doing.
« Reply #203 on: April 26, 2017, 11:57:28 PM »
Stan... even a blind squirrel manages to find an acorn every now and then  :roll:
To continue the hijack, I entered us in I/BFL at SpeedWeek,  will enter in G/FL at WoS and will enter anything not in pieces at the Finals...  :|
Back to your regularly scheduled G/FL thread....
John, looks like you are making great progress.... take more pictures  :cheers:
Offline ggl205
« Reply #204 on: April 27, 2017, 08:47:19 AM »
"I guess he does (and has) known what he's doing."
And therein lies my difficulty. Stainless most certainly does know what he is doing and I am just now trying to find out.
« Reply #205 on: April 27, 2017, 10:04:44 AM »
I guess the hijack continues...
While I enjoy leading the Mountain States Automation Bockscar Team, we are a team!  When I was a lot younger I was fortunate to "fall in with a bad crowd" and have continued to be teamed with some really smart folks for many years (read Ben Jordan, Johnboy, Martyn, Kevin, Corey, Barc and yes, Pork Pie).
Knowing and learning the failure points of mechanical things are far different beasts....  :cheers:
John knows we have tried to take his records on several occasions since 1997... managed to get one in 04, but destroyed a lot of hardware along the way.... there is no easy path in any of this....
although when folks ask about the 200 MPH Club, I usually tell them it is an easy club to join  :roll:
All you have to do is set a record over 200 MPH or the club minimum in your class ....
That means you must go faster than anyone else has since 1953  :cheers:
Now can we concentrate on the task at hand... more pictures John... we need more pictures  :cheers:
« Reply #206 on: April 27, 2017, 11:12:54 AM »
Here's what I don't understand about the 2-Club . . . that first hat is so expensive, yet they almost give away any more after that.
« Reply #207 on: April 27, 2017, 11:41:04 AM »
How expensive is a Dirty 2 hat?
Just curious. I'll never challenge.
Offline ggl205
« Reply #208 on: April 27, 2017, 11:45:17 AM »
"Now can we concentrate on the task at hand... more pictures John... we need more pictures."
OK, I will post a few more images this Saturday. Plan is to begin cutting the body shell and fit all panels to chassis. This sounds like such an easy task but I am dreadfully worried about not getting the cut lines right. Gotta do it sometime so Friday is the day. Measure twice (three times), cut once.
« Reply #209 on: April 27, 2017, 01:55:22 PM »
John, measure with a laser, mark it with chalk and cut it with a sharp axe!  :-D :-D
BTW: After cutting three times it will still be too short!  :-o :-o
