Author Topic: G/F class lakester in Wichita, Kansas  (Read 220551 times)
Re: G/F class lakester in Wichita, Kansas
« Reply #165 on: March 17, 2017, 06:22:49 PM »
The "Star Spangled Banger" FBF/l was (is) owned by Bill Manley from Santa Rosa and was originally built by Dick Russel a noted fabricator that worked for Parnelli Jones in So. Cal. It was made from "spare" Indy car parts and sported a 159 cu. in turboOffy that made about 1000+hps. It used a Weisman tranny and that was its limitation because they could not find a ring and pinion that would allow them to go much faster than their record or 262 mph although they had plenty of power they didn't want to over rev the Offy. Bill had been going to Bonneville for years and even though he had some pretty stout equipment he never set a record, which is something he really wanted to do. He put his son, Brian, who had never been to the salt, in the lakester, he got his licencees and then set the record at 262 mph and his comment was "What is so hard about this"!!!! They say his dad almost hit him!
As I understand the Star Spangled Banger may be for sale and they have found some gears for the Weisman that will allow it to go over 300 so it mite be some competition for you John.
Offline Dynoroom
« Reply #166 on: March 17, 2017, 06:31:55 PM »
Rex, I would be curious about gears for a Weisman transaxle too...
Offline Ron Gibson
« Reply #167 on: March 17, 2017, 08:26:48 PM »
IIRC, If that is the same transaxle Al used, it is based on a 12 bolt GM R&P. I think Al got a set or two of the 2.13/14 R&P that Lingenfelter (sp) had made.
Ron
Offline ggl205
« Reply #168 on: March 17, 2017, 08:48:12 PM »
"I understand the Star Spangled Banger may be for sale and they have found some gears for the Weisman that will allow it to go over 300 so it mite be some competition for you John.
Rex"
Rex, I would welcome the competition.
Offline ggl205
« Reply #169 on: March 17, 2017, 08:51:07 PM »
Dyno room, try contacting Can-Am Racing in St. Louis, MO. They have just about everything in spades for old and new Indy cars.
« Reply #170 on: March 17, 2017, 09:21:51 PM »
The website is www.canamcarsltd.com/ . He has huge stock, lots of cars you'd likely recognize, and is a really good guy to deal with.
« Last Edit: March 17, 2017, 09:23:50 PM by Peter Jack »
Offline ggl205
« Reply #171 on: March 26, 2017, 10:27:15 PM »
OK, I have exhausted every known fastener I think will work to secure my fiberglass body but am not happy with any of them except the Camlock 4002 series 1/4 turn with a Plus-Flush grommet. Only problem with Camlock is the $15 or so price tag each. Dzus fasteners are economical but will eventually auger out the glass hole so I am not over joyed about using them. So, what are you guys using for a reliable fitting on fiberglass that does not break the bank?
« Reply #172 on: March 26, 2017, 10:33:02 PM »
John;
Try these self-ejecting Dzus fasteners:
http://www.speedwaymotors.com/Self-Ejecting-Quarter-Turn-Fasteners-500-Inch-Grip-Pack-10,1573.html
Online Speed Limit 1000
« Last Edit: March 26, 2017, 10:38:19 PM by Speed Limit 1000 »
Offline ggl205
« Reply #174 on: March 26, 2017, 10:48:29 PM »
Neil/Johnboy:
Yes, I have seen an even used some of them before. The self ejecting Dzus are good but I would like to avoid using a riveted aluminum plate on top of the glass. What do you think about a doubler plate on the back side? There are some super strong adhesives that will avoid using rivets. To make the tapered Dzus flush, I would have to ream a taper in the fiberglass. Does this sound like a weak idea?
Offline Ron Gibson
« Reply #175 on: March 27, 2017, 10:31:11 AM »
A very fast liner was that way from 1976 on till retirement.
You could glue on the ss tapered washers, called a half grommet, takes a little bigger recess to keep the Dzus level.
Ron
Offline ggl205
« Reply #176 on: March 27, 2017, 10:32:32 AM »
John;
Neil, it is looking more and more like Dzus with reinforcing and backing plates is what I will use. Not many more affordable alternatives. I will just have to live with the less than desirable aero.
Offline ggl205
« Reply #177 on: March 27, 2017, 10:34:51 AM »
Ron
Ron, these are EXACTLY what I was looking for. You are a life saver, my friend.
« Last Edit: March 27, 2017, 10:38:31 AM by ggl205 »
Offline ggl205
« Reply #178 on: April 04, 2017, 11:04:24 AM »
It has been a long road completing the lakester body shell but the last two finishing laminations were put down last night. Some sanding will take place to remove seams, overlaps and runs but this will be minimal. Can't wait to pull the shell and begin working on the car again. Just five months till WoS so no time to waste.
« Reply #179 on: April 04, 2017, 11:42:58 AM »
Good luck on the glass work. :cheers: :cheers: :cheers:
