Author Topic: Rear Partition - Altered  (Read 9647 times)
Re: Rear Partition - Altered
« Reply #15 on: November 19, 2015, 03:39:44 PM »
MrE;
One disadvantage I can think of having the fuel tank up front is that in a fire your fuel tank is a torch with the flames going back toward you. Otherwise it sounds like a good idea.
Depends if you have spun around or not at that point  :evil: :evil:,
Offline jacksoni
« Reply #16 on: November 21, 2015, 09:36:06 AM »
With a small engine and short course only I ran a 3 gal cell in the front of my Firebird. Worked well, avoiding all the issues of tanks in the drivers compartment, fuel lines in the region of the fly wheel etc etc. If you have space for it, I think is a good idea and as noted you can then use the rear tank for ballast as needed.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #17 on: November 21, 2015, 09:54:59 AM »
MrE;
Yep, but any fuel problem is the same thing... feeding a fire till you turn off the pump... and turn on the fire suppression.  I think your small tank in the front idea is the best solution to your dilemma.
have fun  :cheers:
