Author Topic: ZF 8 speed automatic.  (Read 4748 times)
« on: October 17, 2015, 10:49:42 PM »
Always on the lookout for the good stuff and seeing as I'm building the only liner in Africa
I figured I'd contact ZF South Africa for sponsorship on their 8 speed auto tranny.
I spoke to a great guy that said they'd love to help. The unit can handle 1000HP and has an overdrive of 0.667.
The only problem is that the box won't work in an aftermarket scenario. It's aligned with the VIN, key, central locking and
about 30 other components from inception.
He's looking into an alternative or maybe a race box from HQ in Germany for me.
I'm not holding my breath though but at least I won't die not knowing.
I said even a 5 speed with a good overdrive would do, I can't be fussy.
I've been lucky so far and who knows?.
Re: ZF 8 speed automatic.
« Reply #1 on: October 17, 2015, 11:50:58 PM »
....and has an overdrive of 0.667..
Sounds interesting :cheers:.  I'd hope there were a number of overdrive ratios before you got to the .667 (at least 1) so steps after each shift were dropping the rpm's less and less after the shift.
Offline sofadriver
« Reply #2 on: October 17, 2015, 11:51:23 PM »
That would be terrific!  Good luck!
Mike, where are you planning to run at?
Mike in Tacoma
Bike #833
Offline Buickguy3
« Reply #3 on: October 18, 2015, 10:04:35 AM »
   Yep, 7th is O.D., too. 6th is 1.00.       https://en.wikipedia.org/wiki/ZF_8HP_transmission
                   [America]
« Reply #4 on: October 18, 2015, 02:34:27 PM »
Mike;
That ZF sounds like a great transmission. There's gotta be a way to hack the controls.
« Reply #5 on: October 18, 2015, 07:17:25 PM »
It seems to me that it shouldn't be that difficult to eliminate the torque convertor and change the shifting to manual control. Just don't tell the transmission there are no computers involved.  :-D :-D :-D
Offline ronnieroadster
« Reply #6 on: October 18, 2015, 09:55:16 PM »
Wow wonder if they can chop that down to about a foot long sure woud be nice as shortened version.  :-)
Offline John Burk
« Reply #7 on: October 18, 2015, 10:40:38 PM »
The 6 speed automatics in later F150s are a ZF design built by Ford . 5th and 6th are OD . I'd be surprised if they handled 1000 HP .
« Reply #8 on: October 19, 2015, 02:06:01 AM »
If I had someone local that could bypass the computer stuff I'm sure we could do something.
We'll wait and see.
Mike, we'll be running at Hakskeen Pan here in SA.
I'm going to get hold of the guy today and bend his mind a bit.
For the most part South Africans are conservative and companies, RISK AVERSE!!!!!!.
I think it all has to do with keeping your job. Cover your Acura.
I'll keep you updated. BTW, I drove this Merc 355 AMG with a serious Brabus conversion on it Saturday.
My friend has a thing for these cars. I liked the paddle shift and the seamless shifts.
Offline jacksoni
« Reply #10 on: October 19, 2015, 08:49:12 AM »
http://www.zf.com/corporate/en_de/magazine/magazin_artikel_viewpage_22066344.html
All they did was jigger the software to make it a paddle shift only race trans. Oughta work for you!
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #11 on: October 19, 2015, 10:58:10 AM »
After all the ECU control $hit they are just a bunch of solenoids. I've built manual shifters for electronic transmissions using micro switches that have worked great. You just need to apply the appropriate solenoids at the appropriate time. If the shift is too hard put a governor pressure de-activator switch on the shifter or just wire in a resistor for the shift quality you need. Get a full ratchet shifter that goes both ways & modify it for as many positions you need, now you can up shift & down shift.
I've done them for Allison, 4L80e & Jatco trans.
