I'm sure this is a complicated question, but I'm looking to start simple: I'm at 174mph and want to start working toward 200mph in the standing mile at Ohio. I have found that f-body.org/gears/ is very accurate to my car when it comes to modeling tire size, rearend ratio, trans ratios and rpm. I understand that I will need a lot more power to make the jump, and that I will need to make the safety mods required in the rule book. What I'm looking to work out at the moment is rear gear and transmission ratios. The help I need from you smart and experienced guys is: what rpm do I need to gear for? In other words, do I want to go they the timing lights at the rpm peak on my dyno curve, or some other rpm? Currently my car goes thru the beams at 174mph at 6200rpm. My peak torque is at 4150rpm and my peak hp is at 5450. With current gears, Im at my peak hp rpm at the 1/2-mile point. So, for the second 1/2-mile, I'm racing with progressively less hp as I approach top speed and the timing lights. Please offer advice.
