Author Topic: ratty RPM signal from MSD + Racepak????  (Read 11903 times)
Re: ratty RPM signal from MSD + Racepak????
« Reply #15 on: September 29, 2015, 08:11:42 PM »
It sounds like the output could use some low-pass filtering to clean it up.
Offline entropy
« Reply #16 on: September 30, 2015, 06:24:27 AM »
Thanks to everyone for your help, I think we are on the road to a solution.
At least now i know the issue is likely equipment  compatibilty and maybe not my shade tree mechanical approach.
I'll post up results when we next test.
Karl
Offline entropy
« Reply #17 on: October 07, 2015, 11:15:34 AM »
update
BVCBR's post put me in contact with him, Jamie Wagner, at MSD.
I gotta say JAMIE'S TECH SUPPORT IS THE BEST I'VE EVER EXPERIENCED.
Multiple emails have explained why the MSD distributor is outputting a signal which will drive an analog tach just fine, but is almost unusable for Racepak rpm input.  I am down the path of installing a MSD Digital 6AL Ignition Controller which has a tach output with the square wave the Racepak needs.  But also Jamie has provided me with tach signal convertor  8132 which should work on the GM HEI system i am replacing (this is in case i go back to that system)
     Some TFA household complications are slowing my controller install & testing, but for the 1st time in 2 years i feel i understand the problem and likely have an answer.
     to be continued...Karl
Offline entropy
« Reply #18 on: May 18, 2016, 06:53:18 AM »
whoa!  Looks like i never closed this one out.
I installed the MSD Digital 6AL Ignition Controller and my ratty rpm trace on my Racepack looks beautiful
Jamie Wagner at MSD:  kudos to you!!!
karl
Offline BVCBR
  • Pflum & Wagner Racing
    • Gotfastbikes.com
« Reply #19 on: May 18, 2016, 08:48:48 AM »
I'm glad that fixed it up.
By the way, I'm Jamie at Holley now. When Holley bought MSD, they moved me to Kentucky. I can still help out with any MSD issues though.
JW
970B 1000cc P-P
976B 1000cc P-P
977B 1000cc M-G/F
Offline entropy
« Reply #20 on: May 18, 2016, 10:11:16 AM »
Jamie,
I will not forget how much you helped me on my tiny little problem.
Lots of sales/techs provide great customer support when 10's of thousands of dollars are in play.
But the guy who also does it when just a couple hundred bux is being spent does it because that's just the kind of person they-YOU are.
Karl
Offline JamesJ
« Reply #21 on: May 25, 2016, 02:42:54 PM »
If you ever need to look at a setup we have tow cars in town with IQ3 and MSD boxes...
We had a problem similar to yours, tried everything, ended up just getting a new box and worked fine.
James
Offline entropy
« Reply #22 on: May 26, 2016, 11:55:57 AM »
James
James,
Thanks a million for the offer.  Everything seems fine now w/the MSD box, i just went thru a bunch of gyrations getting there.
Are you planning on going to Speed week?
karl
