Author Topic: First Time Racing - Motorcycle  (Read 2063 times)
Offline Canadian FJR
« on: September 20, 2015, 06:23:54 PM »
Hi Folks,
I read through the rules but did not find what I am looking for.  I assume that you need to prove that you can run safely under a certain speed before you start to make some serious runs.  Can somone point me in the right direction of how this process takes place.
EDIT:  I found the required info.
Canadian FJR
« Last Edit: September 20, 2015, 07:27:54 PM by Canadian FJR »
Jessechop
Re: First Time Racing - Motorcycle
« Reply #1 on: September 20, 2015, 08:23:02 PM »
For those that may be wondering about this refer to rule 1.M
The passes will be 120-130mph
145-155
170-180
etc.
« Reply #2 on: April 19, 2016, 04:32:53 PM »
How do vehicles without speedos handle the licensing process or is it mandatory that they have some sort of device to monitor their speed in order to stay within rule 1.M ?
Canadian FJR
« Reply #3 on: April 19, 2016, 04:44:43 PM »
You should be able to figure it out from your tach readings provided you know your gearing. The situation is the same where ever you go. The other alternative is a GPS.
« Reply #4 on: April 19, 2016, 05:36:52 PM »
Sounds good, thanks for the reply.
Canadian FJR
Jessechop
« Reply #5 on: April 19, 2016, 06:43:55 PM »
What I do is go to gearing commander,  punch in the info and see where I need to be.  I.E. 5500 on 4th is 150 and so on.  Prior to that pass it tape that on the tach so I  see our on track
