The PolyQuad valve system is for four and five valve cylinder heads. The intake valve on one side is larger than its mate, and the exhaust valve on the other side is larger than its neighbor. It is claimed to promote swirl in the combustion chamber. This idea has been around for awhile. Has anyone tried it and how did it work? Any increase in peak power?
"Swirl" is used to help combustion efficiency in two valve engines. Imagine, if you will, a small 'tornado' in the cylinder as it is being "squeezed". Rotation is vertical with respect to the cylinder axis.
"Tumble" is a similar, but different phenomena, in 4/5 valve engines. It is theorized that tumble is swirl, produced
horizontally. Rotation is horizontal with respect to the cylinder axis. Duckworth's original description of the phenomena was "barrel-roll".
The efficacy of swirl & tumble is evaluated based on the reduction in ignition timing required to produce an equivalent amount of torque or bhp, inferring heightened efficiency. The control baseline would be the same engine without the phenomena. Very sophisticated flow measurement devices are used to quantify swirl or tumble while flow measurements are being done.
Increased swirl or tumble doesn't always produce more bhp. Often an increase in swirl or tumble results in a similar bhp with lesser ignition requirements. This is less stress on engine components, always of value . . . Poorly performing combustion chamber shapes typically benefit the most from swirl/tumble. Well designed chamber shapes typically have these effects designed in.
PolyQuad is Vizard's copyrighted concept for combining the two effects. To the best of my knowledge, which is more limited these days, only Vizard is publishing about any effects or results. One of his books describes this work on a Mitsubishi (?) 4 valve in detail. Sorry, I don't recall the % differences.
If I was using the concept successfully, I would
NOT be talking about it, as Vizard would be entitled to a fee under his copyright/patent (?).
