Author Topic: 2015 Maine Event Live Audio Streaming  (Read 8579 times)
gkabbt
« on: July 22, 2015, 07:31:35 PM »
Since this is my 1st time streaming from the LTA, I am unsure when broadcasting will begin.
I'm assuming it will begin after the drivers meeting on Friday and then around 7:30 AM on Saturday and Sunday.
I will update this thread when I begin the stream.
I would like to say thanks to the LTA for allowing us to do this and Jon for supplying the Wi-Fi hotspot/Meridix software!
If you have any thoughts, suggestions or comments, please post them here! As we have said before, this is a continuing experiment.
As usual, I hope you enjoy,
Gregg
« Last Edit: July 22, 2015, 07:36:23 PM by gkabbt »
Offline RansomT
Re: 2015 Maine Event Live Audio Streaming
« Reply #1 on: July 25, 2015, 08:59:12 AM »
Yea!  It's live!
gkabbt
« Reply #2 on: July 25, 2015, 09:04:20 AM »
Thanks Ransom.
I was about to say we are live and you beat me to it!
We should get underway shortly.
Gregg
Offline RansomT
« Reply #3 on: July 25, 2015, 09:25:05 AM »
But all I hear is the starting line without the benefit of the announcer...no number, no results.  :(
gkabbt
« Reply #4 on: July 25, 2015, 09:33:32 AM »
Should be good to go now Ransom.
Gregg
Offline RansomT
« Reply #5 on: July 25, 2015, 09:45:04 AM »
The gain could come down a bit.
gkabbt
« Reply #6 on: July 25, 2015, 10:03:36 AM »
Done. Let me know if it's OK.
Gregg
Offline RansomT
« Reply #7 on: July 25, 2015, 10:10:29 AM »
Yes, it sounds much better...but I've lost the feed now.
« Reply #8 on: July 25, 2015, 10:26:15 AM »
I heard "car is smoking a lot" and then "roll fire and rescue" then the audio cut out. Hoping all are ok.
gkabbt
« Reply #9 on: July 25, 2015, 10:35:56 AM »
Ed Brace had a rear axle lockup which smoked the tire and caused it to blow.
I heard he went off the end of the track and is OK.
Gregg
gkabbt
« Reply #10 on: July 25, 2015, 10:38:11 AM »
I've seen the feed come as well. Must be the cell tower location.....Nothing  I can do.
Gregg
Offline Bullfrog
« Reply #11 on: July 25, 2015, 11:04:43 AM »
Thanks for providing the audio feed! I was bummed that I have to work and can't make it this summer. The feed has now stopped for about a half hour and say's "Off Air", are you having problems?
Offline RansomT
« Reply #12 on: July 25, 2015, 11:19:50 AM »
When I raced there in 2009, the only cell tower that I could reach while at the track was in Canada.  International Rates!
gkabbt
« Reply #13 on: July 25, 2015, 11:23:23 AM »
Meridix software did drop. I just restarted so it should be good to go. You should have the Listen Live again.
I'll keep a closer eye on the laptop.
Things are quite now as they are doing a quick course sweep.
Gregg
gkabbt
« Reply #14 on: July 25, 2015, 01:13:35 PM »
Down for cleanup as Mike Reichen lost an engine in his Mitsubishi EVO.
Gregg
