Author Topic: 432 cu. in. BBC  (Read 2151 times)
Online toclub
432 cu. in. BBC
« on: July 02, 2015, 07:54:53 PM »
4.280" bore chevy block, 'O' ringed, copper gaskets. 3.750" stroke Castillo lightweight crank, profiled and pendulum cut, 55lbs. JE pistons, 14.5 to 1, gas ported w/ zero gap rings. Eagle 'H' beam rods w/ L-19 bolts, coated bearings. Crane .737" roller w/ .837" roller lifters. Jeff Johnson 6qt. sheet metal pan w/ Titan oil pump. Alum. Pro Comp heads, CNC'd 110 cc chambers. 2.300" Tit. int. valves. 1.88" SS exh. valves. 1.670" triple valve springs. Jessel 1.7 "shaft" rockers. Sheet metal valve covers. Smith Bros. push rods. Holley pro ram intake manifold w/ two tops. 2 1/2 passes at the salt since freshened. Went 234 MPH on second full pass in 4500 lbs. door slammer. Complete and assembled $3500 plus shipping. Call Glen @760-241-5334
Re: 432 cu. in. BBC
« Reply #1 on: July 14, 2015, 08:22:16 AM »
 :-o
WOW - that is a screaming deal, and just at the time when I'm catching "Jet Boat Fever".  It happens every summer that there's not a boat parked in my garage.
I'm thinking of about a 20 foot classic day-cruiser, fully polished thru-hull exhaust, a slight ripple on the water, and a beautiful woman in a bikini at my side (my wife).
Ahhhhhhhhhhhhhhhhh
