From scta facebook
SCTA Southern California Timing Association
7 hrs ยท
Below you will find some BLM Stipulations we all must follow. Also, PLEASE put a tarp or carpet under your Race Vehicle when parked in your pits - It is a MANDATORY REQUIREMENT
BLM STIPULATIONS - FUEL & FLUIDS MANAGEMENT:
The permittee is required to inform all persons associated with the SRP directly or indirectly of this stipulation requirement.
ALL VEHICLES โ A method of controlling and capturing fuel spilled during fueling must be placed under all dump cans and under each vehicle during fueling operations. Commercially available absorbent products are available but a piece of scrap carpet is acceptable as long as the carpet absorbs the fuels and does not simply allow the fuels to run off or drain through.
ALL PITS WITH 50 OR MORE GALLONS OF FUEL โ All pits that have 50 or more gallons of fuel available, whether in drums or dump cans, must provide for fuel containment. At a minimum this requires โ 1) an impermeable membrane with raised edges capable of containing all fuels on site should the containment vessel fail and 2) absorbent materials (commercially produced spill pads, diapers) available to soak up spilled fuels. This does not apply to fuels located within fuel trucks or fuel drums not in use store in trucks or trailers
