Author Topic: Cooling system expansion tank??  (Read 8701 times)
dwarner
Re: Cooling system expansion tank??
« Reply #15 on: December 21, 2006, 11:08:43 PM »
Sparky,
What do you mean by "... through resevior then overboard"? Are you dumping water during a run?
Offline Dean Los Angeles
« Reply #16 on: December 22, 2006, 12:13:25 AM »
Let me see if I can interprete what DW said:
Dumping water on the run = Not running on my damn track again!
« Reply #17 on: December 22, 2006, 08:07:25 AM »
miss spoke---I should have used the term" 1 pass"---it will go to another tank in the nose now to shift the CG forward. I am planing to cool the exhaust with a jacket  around the the exhaust pipe like boats when I  turbo, for I will need the nose tank for additional cooling water capacity.
« Reply #18 on: December 22, 2006, 10:39:39 AM »
Sparky,
You said that you were thinking about cooling the exhaust? I hope you are talking about the exhaust from the turbo not the exhaust going in.
Offline Loose Goose-Terry#1
  • Terry
  • When in doubt, GAS IT!
« Reply #19 on: December 22, 2006, 11:08:27 AM »
 :? Anybody ever try running a sea pump like used by Mercruiser on the Offshore Race Boats? Or for that matter maybe even the standard sea pump used on the offshore pleasure boats? :-D
Terry
Offline Dynoroom
« Reply #20 on: December 22, 2006, 02:29:42 PM »
Terry
Yep, it'll work for most. I've used one as a charge air cooler pump too!
Offline ddahlgren
« Reply #21 on: December 23, 2006, 08:35:24 AM »
Sparky riddle me this will ya. Why do you want to take energy out of the exhaust?? Are you worried it might make some boost and you want to avoid that.. Ya have my # give a call sometime we need to talk..LOL
Dave
« Reply #22 on: December 23, 2006, 03:04:50 PM »
Definitely--after the turbos--exhaust pipe only---header pipes will be thermal coated in front of the turbos
