fb,
Thanks for the reality check
, there are those "rare" moments when the guy that throws the box away...
... when asked by the principal if the glass was half empty or half full, I told him it was either neither or both,... and then I got thrown out of his office! (true story)
Ronnie,
That was some of my thinking is packaging. Everything fits quite neatly in a rear engine set up with the tank the other way.
Stan,...
Interesting.
Question#2,
If applying the airfoil as intended in WWII,... would you or would you not flat the bottom? I got old man Newt & Bernoulli's take,... & the concept of lift I understand. what I am asking is if you leave the bottom curved: "do you compress the air below you when only inches from the ground(not in an unlimited space above below wind tunnel scenario), causing the very effect you are trying to avoid? Or does the airfoil adequately displace the air around the design,... mitigating this effect?"
http://www.flatfire.com/
