Author Topic: XF/GL Engine Rules/Possibilities???  (Read 18663 times)
Re: XF/GL Engine Rules/Possibilities???
« Reply #30 on: February 18, 2015, 11:52:34 PM »
do not forget the crunchies if you are going to run B'Ville
Offline Jack Gifford
« Reply #31 on: February 19, 2015, 12:52:59 AM »
... You must have thee flathead of all flatheads if you need desmo valve control...
 ... There was never desmo... valve control during the vintage era...
I agree about no known flathead needing desmodromic.
But there's seldom anything "new under the sun" in engine development; pretty much everything has been tried before. In the mid 1920's there was a sleeve valve car engine that was desmodromic. Instead of the usual crank/rod arrangement to move the sleeves, it had one camshaft to lift them and another to lower them. Probably also was some "vintage era" desmodromic poppet valve engine, but I can't think of one right now.
« Last Edit: February 19, 2015, 12:55:16 AM by Jack Gifford »
M/T Pontiac hemi guru
Offline FABRK8R
« Reply #32 on: February 19, 2015, 06:53:32 PM »
Jack,
hmmm,... too many years in Deutschland has me spelling it Desmotronic "Desmodromic" Lol
anyhoo,... got the idear looking at Momma's 695 Monster,... thought it was worth the question & conversations :-D
Pickle,
hmmmm,... Wondered about the high rig too,... kinda like put the tank in the clean air. My thought on low & flat was that it would trim off some frontal area to make the hole in the air "mo-smallish"!
Offline NathanStewart
« Reply #33 on: February 20, 2015, 12:52:57 AM »
Jack, I'm sure you're right about desmo existing in one form or another but when I say there was no desmo in the vintage era, I meant the vintage dry lakes racing era. That seems to be what our vintage rules are based on largely... unless we're talking ignition systems.  Anyways...
El Mirage 200 MPH Club Member
« Reply #34 on: February 21, 2015, 12:21:40 AM »
Nathan- yeah, I understand the spirit of the 'vintage' classes & rules. Just wanted to throw in my 2 cents-worth of engine trivia. The example I was remembering was 1923 - 1934 Imperia (Belgian; ancestor of the present-day Imperia high-performance hybrid car). But I remembered wrongly; it was desmo slide valves, not sleeve valves.
Offline FABRK8R
« Reply #35 on: February 26, 2015, 07:01:00 PM »
Way I understand it though,... other than the block being an old flatty & no overhead valves,...
 XF/GL is a special construction class, which is not as "restrictive" about things like EFI & such like the vintage classes according to the RB.
I also understand the just because you can, should you? & in the spirit of being historicaly correct,... mucho respect for the trad rodders.
Offline RichFox
« Reply #36 on: February 26, 2015, 07:49:56 PM »
You sure won't be the first one to run EFI on a flathead. If you want to, go for it.
« Reply #37 on: February 26, 2015, 08:40:43 PM »
Next thing you know he'll want to let the 1952 air out of his tires and put in new stuff.  :roll: Wayno
Offline dw230
« Reply #38 on: February 27, 2015, 12:24:24 PM »
If you want to see your competition using EFI will keep you within sight of them.
Offline FABRK8R
« Reply #39 on: February 27, 2015, 01:16:20 PM »
psssssssssssssssssssssssshhhhhh!
 :-D
I am leaning towads a custom manifold, port fuel injection(20 or 22lb target of 250-280hp), crank trigger, wideband O2's & a mega squirt computer. GDI seems counter productive because of the style of engine(being side valve) in question. Anyone have good examples of similar set ups on Flatheads. Like ya'll say, surely not the first. Have found many on the web,... just asking of examples being run here?
Really do like the old hilborn set up for nastalgia sake,... but think I'm gonna go a bit more intuitive.
« Last Edit: February 27, 2015, 01:54:45 PM by FABRK8R »
« Reply #40 on: February 27, 2015, 02:02:04 PM »
I have just 2 part throttle passes at El Mirage on my setup. We'll know more this year. Wayno
Offline saltracer1
« Reply #41 on: February 27, 2015, 07:32:23 PM »
My project so far, efi with Eaton supercharger
bought a lot of the stuff to build the intake from http://www.rossmachineracing.com/
« Last Edit: February 27, 2015, 07:36:57 PM by saltracer1 »
