Author Topic: Setting toe with "Quick Trick" - not useful for TFA's lakester  (Read 13631 times)
Offline entropy
« on: January 18, 2015, 06:50:08 AM »
Some of you fine folks have participated in TFA's 101-level questions about the construction and handling of our lil blue lakester.
As a result, setting toe accurately at the track is now on our list.
We recently bought a "Quick Trick" alignment tool and it seems pretty straight forward.
demo of it being used:  http://www.youtube.com/watch?v=aadqjpyqlfs
Q; does anyone have any tricks for using the Quick Trick?
Karl
« Last Edit: July 24, 2015, 05:44:43 AM by entropy »
Offline JimL
Re: Setting toe with "Quick Trick"
« Reply #1 on: January 18, 2015, 09:23:32 AM »
Dont know, but heres how to cross check your method.
Open wheel car...pretty hard to beat two jackstands, string, and a tape measure.  That method also lets you check rear axle thrust angle, though its nice to do that with another pair of jackstands and more string.  You should set the front wheels to zero while checkng the thrust angle this way, just to be sure you are dead straight to your Ackerman and scrub radius.
You're just running the string loop across the tire faces (wrapped around the back of the tire, tied off to the  axle) and moving your jackstands in or out to get each side parallel.  With the jackstands 6-10 feet (or a lot more if you have room) in front of the tires, you get very fine accuracy.  You are measuring the strings, out front, to get them parallel, and then your toe-in shows as a small gap at the forward sidewall of the tire.  Comparison check the tire sidewalls to the rims, to be sure you arent measuring a bulge.
With the front tires dead straight and parallel (no toe-in) you can pull string from the rears, passing the fronts, to measure for parallel and thrust angle.  If the rear tires are narrower than the fronts, use wood blocks vertical to space out from the sidewalls.
Note about the wood block trick....pretty handy for using this method on fendered cars.  Just make an H out of 2x4s that can stand against the sidewalls and pull your string loop.  Dont fuss with string tension by retying....just slide a jackstand forward.
When you finish, do the water puddle trick on each side to make sure you are right (or that you werent actually straight...I've caught myself on that one).  On flat concrete or pavement, pour a water puddle on the ground and hand roll thru it with the wheels dead straight.  You can measure any offset right there on the floor when the front and rear tracks show on top of each other.  (This old trick can be pretty discouraging when you just bought that brand new, whiz bang, super duty dually for a gazillion dollars.  Just take a jug of water to the Walmart parking lot on a Sunday morning, drive through the puddle straight, cross your fingers and then walk back for a look-see.)
No matter how you measure or what tools you use, failing the water puddle test is the final answer for thrust angle.  Flat ground and tires dont lie.
Maybe this is a dumb post and I am preaching to the choir, but sometimes we forget how well the old ways still work.  A fellow starts getting a little gun shy when the thinking starts muddling with age, so I have to delete most what I write these days. :oops:
JimL
« Last Edit: January 18, 2015, 09:26:37 AM by JimL »
Offline 55chevr
« Reply #2 on: January 18, 2015, 10:31:22 AM »
Nice catch Karl .... $285 from Summit.
Offline entropy
« Reply #3 on: January 18, 2015, 10:47:32 AM »
JimL
Thanks for posting ways to get to alignment without expensive tools.  At the beginning I did my bikes with strings & jackstands.  It worked, but i gotta tell you i cursed those pink strings more than once as i tripped over them  :-D
Joe,
Credit Joe Timney, he apparently saw it at PRI? :cheers:
People seem to agree that each car is likely to have its own "sweet spot" toe adjustment.  And that you can only get to that sweet spot by: make a pass/ make an adjustment, repeat, repeat as needed.
The Quick Trick might make it easy to make accurate adjustments on the salt; we'll see.
Karl
« Last Edit: January 18, 2015, 11:14:09 AM by entropy »
« Reply #4 on: January 18, 2015, 12:26:20 PM »
Two things to watch out for.
First be sure that the surface you have the vehicle resting on is level. A laser level is probably the easy way to check that these days and floor tiles or squares of sheet metal are probably the easiest things to use as shims.
Secondly, all tapes are not created equal. Take both tapes and hook them to a common straight edge right beside each other. Pull them out to the approximate distance you'll be measuring. Check to see that they're measuring the same distance at that point. I've seen them vary by as much as an eighth of an inch. You can imagine how that can contribute to your sanity and handling if you measure twice and reverse which tape is where each time.
Have fun and buy a GOOD set of knee pads or get a younger helper.
« Reply #5 on: January 18, 2015, 02:58:54 PM »
This type of system has been around forever in some form or another in the oval track world. The problem with it is you have no way to reference the wheels accurately straight ahead so caster, ackerman & scrub will all affect the results. Centering the steering wheel is "kinda close" so you will be "kinda accutate".
« Reply #6 on: January 18, 2015, 05:51:34 PM »
I made 4 brackets (2 at the front of the car and 2 at the rear)....
... that can be bolted to the car anytime, anywhere which will then...
...allow me to string the car.  Of course this is a lakester (or might be one some day) so no body work in the way but will have to remove some to put the brackets in place.
More here ....
http://purplesagetradingpost.com/sumner/bvillecar-2/construction%20page-79.html
Offline entropy
« Reply #7 on: January 19, 2015, 05:08:00 AM »
more good info, thanks!
"Secondly, all tapes are not created equal..."  Excellent, i NEVER would have considered that.
"buy a GOOD set of knee pads"  I worked for 30+ years in a big corporation and am fully equipped with kneepads
KBT
"no way to reference the wheels accurately straight ahead"  hmmmm... what is easiest way to do that?  String?
Thanks a million for reminding me of your excellent site!
Karl
« Reply #8 on: January 19, 2015, 11:32:35 AM »
I like to use an aluminum "yardstick" with a built-in red laser (Harbor Freight, less than $10) in place of string. Place the thing against the wheel (or hub if the wheel is dismounted) and project the laser beam against a distant flat wall and mark that spot. To account for the laser's not being exactly aligned with the straight edge of the yardstick, turn it over on its back edge and mark that spot on the wall. Half way horizontally between the two spots will be the accurate "center"-- the actual data point. Do the same thing on the other side & measure the distance between the two data points.
Next, roll the car forward or set up a flat panel as close to the nose of the car as possible and repeat the procedure. If there is zero toe-in, the two measurements will be equal. Some geometry calculation will give you the toe angle if the measurements are not the same.
You can place the laser against the rear tire and see where it aligns relative to the front to check tracking. If you have an independent rear suspension like I have, you can also run a similar procedure to check the rear toe angle.
By placing the laser on the exact center of the body and aligned with its axis, you can tell if the wheels are pointed straight with the body or whether the car is "crabbed". The center-to-left distance should be the same as the center-to-right.
It helps to have the body off but the wood block spacer idea works just as well with a laser as it does for string.
Online John Burk
« Reply #9 on: January 19, 2015, 11:47:55 AM »
I made my toe checker out of 6 ft of 1 1/4" square aluminum tube . This is with the wheels removed . An 18" and a 36" are bolted together like a framing square with a hole in the short leg that goes on a wheel stud . An 18" one by itself goes on a wheel stud on the other side with a lug bolt on each . The in out motion with the long one laying against the single one is the toe . The stiffness of the tube makes the hubs turn together so it only takes one person . Things are in the way so I check it back 90* and 0* to the king pin axis and double the reading . The reading is at greater than the tread radius so I factor that in . A good level on the hub flange tells if if there is any camber to factor into the toe reading . From everything I've seen toe-in helps going straight and toe-out helps turning corners .
Offline jdincau
« Reply #10 on: January 19, 2015, 12:45:16 PM »
Here is how I do it, it is simple, requires no bulky to transport equipment and can be done in the pits at the salt.
I use a piece of aluminum channel and two framing squares.
1. Mark a reference line on the circumference of the front tires by jacking them off the ground and spinning against the marking tool.
2. With the car on the ground roll it forward centering the wheels and taking out the slack in the system.
3. Slide the channel under the rear of the wheels and clamp the framing squares to it on the marked lines on the tires keeping the squares perpendicular to the floor.
4. Carefully move the rig to the front of the tires and with the squares again perpendicular to the floor align one square with either wheel reference line, at the other wheel reference line measure the distance from the reference line to the edge of the square. That distance is your toe out/in.
Note, the reference lines do not have to be in the exact center of the front wheel since we are only looking for a difference from front to rear not the exact tread measurement. Also since we are only measuring toe the car does not have to be level just on a reasonably flat surface. Another thing the circumferential lines molded into the tire never have zero run out so you can't use them as a reference.
« Last Edit: January 19, 2015, 12:52:49 PM by jdincau »
Offline entropy
« Reply #11 on: January 20, 2015, 06:07:48 AM »
Thanks guys!
Much appreciated! :cheers:
karl
Offline Ron Gibson
« Reply #12 on: January 21, 2015, 10:30:51 AM »
Using JD's method, after an adjustment, roll the car ahead  and remeasure. That takes out any slack, pre-loads the joints as JD said and is the toe the front end actually sees driving down the track.
Ron
Offline entropy
« Reply #13 on: January 21, 2015, 10:34:05 AM »
Ron
Ron,
THAT's exactly the kind of tip which can help my ignorant a$$ have a higher probablility to "do it right"
Karl
Offline Buickguy3
« Reply #14 on: January 21, 2015, 09:48:27 PM »
   Not sure that this applies to the Salt, but in our drag racing days in stock class we noticed from a picture of our car at mid track that the front was lifted about 4-5 inches from what it was on the starting line. We had set the toe at rest. We found that when we raised the front end to the mid track attitude everything changed. Camber and toe. Worth taking a look at.
                   [America]
