Well..... if it were me......
I'd use a 4.6 iron block (8.937 deck ht)
If you are going to use a billet crank might as well have it made to use WIDELY available chevy rods.
Use a 3.250 stroke and choose a rod journal you like: 1.880, 2.000, or 2.100.
All kinds of rod lengths out there with the basics being 5.700, 5.850, 6.000, 6.125, 6.200 right off the bat.
And if your worried about the rod/stroke ratio (I wouldn't) it's around 1.8 to 1.9 which is fine.
You 1.800 compression height is a killer for piston weight. With the 3.25 stroke & a 6.00 to 6.125 rod your compression height would be 1.312 to 1.187. lighter piston but still enough room for a durable ring pack.
I run more compression than most but I would run at least 9.0:1 (my current car is 10.5:1) Yes with turbos...
As for the rest, we can't tell you everything, what fun would that be?
Good luck & have fun.
Who holds that E/BGR record anyway........
