Author Topic: Motorcycle speed in gears  (Read 65733 times)
Offline sofadriver
« on: December 20, 2014, 04:30:28 AM »
Been a long time since Algebra 1.
Can anyone change this around to find speed?
            speed x 336 x pri x gear x     big
RPM =                                            small
                            diameter
Thanks in advance
Mike in Tacoma
Bike #833
Offline stay`tee
Re: Motorcycle speed in gears
« Reply #1 on: December 20, 2014, 06:56:18 AM »
mph = (rpm x tyre radius) / (primary x drive x final x 168),,   8-)
Offline sofadriver
« Reply #2 on: December 20, 2014, 08:01:43 AM »
Thanks, stay'tee.
Couldn't get that to work with the 168 (although 491mph would be coolish!).
Seems to work with 336, though.
I come up with 138mph and that works for me!
I've got more sprockets and more rpm than the figures I used.
But I'm still hoping for a little tailwind!  :-D
Mike in Tacoma
Bike #833
Offline 55chevr
« Reply #3 on: December 20, 2014, 10:16:05 AM »
http://www.cosportbikeclub.org/misc/SpeedCalc.html
This is plug and play - no algebra
Offline panic
    • My tech papers
« Reply #4 on: December 20, 2014, 11:05:02 AM »
Let:
S: speed (MPH)
D1: primary drive ratio (clutch wheel ÷ motor sprocket, etc.)
D2: secondary drive ratio (rear sprocket ÷ transmission sprocket, etc.)
G: individual transmission ratio (2.50, etc.), direct drive high gear = 1.00
T: tire diameter (inches)
R: engine speed (revolutions per minute)
S = (T × R × .002975) ÷ (D1 × D2 × G)
R = (S × D1 × D2 × G) ÷ (T × .002975)
D1 = (R × T × .002975) ÷ (S × D2 × G)
D2 = (R × T × .002975) ÷ (S × D1 × G)
« Last Edit: December 20, 2014, 11:09:03 AM by panic »
Offline sofadriver
« Reply #5 on: December 20, 2014, 12:50:16 PM »
interesting.......
sta'tee's method - 138mph
55chvr's online calculator - 178mph
panic's method - 144mph
Mike in Tacoma
Bike #833
« Reply #6 on: December 20, 2014, 12:53:17 PM »
I'd use the 178 -- it's faster.  Just say it's the Exit Speed if it doesn't match your time slip.
Offline sofadriver
« Reply #7 on: December 20, 2014, 12:58:13 PM »
my choice, too!  :-D
Mike in Tacoma
Bike #833
Offline Vinsky
« Reply #8 on: December 20, 2014, 01:24:05 PM »
Here's one that covers just about ever variation you can come up with.
http://www.rbracing-rsr.com/gearspeed.html
Offline Sporty Dan
« Reply #9 on: December 20, 2014, 02:13:22 PM »
Have you tried the gearing calculator that Sumner put together? It allows you change sprockets to compare in addition to transmission gears. It's down 2 threads here.
Offline panic
    • My tech papers
« Reply #10 on: December 20, 2014, 07:40:24 PM »
55chevr's page is correct - if you input your tire size and drive ratios correctly. The 178 mph result is a GIGO error.
Offline stay`tee
« Reply #11 on: December 20, 2014, 09:31:48 PM »
whats a "GIGO" error,  :?,,
in relation to the formula i posted, (primary x drive x final), "drive" is the ratio of the drivin gear, eg 5th @ 1.130,, "final" is the ratio of front to rear sprocket, eg 18/42 = 2.33,,  :cheers:,,
« Reply #12 on: December 20, 2014, 09:48:52 PM »
Garbage in garbage out...  :cheers:
Post the particulars and I'll put it thru our calculator
« Last Edit: December 20, 2014, 09:51:34 PM by Stainless1 »
Offline sofadriver
« Reply #13 on: December 20, 2014, 10:52:42 PM »
Thanks, Stainless.
Final drive.....3.4
1st....2.54
2nd....1.89
3rd....1.5
4th....1.25
5th....1.09
6th....0.96
front sprocket - 17. rear is 35.
tire is 23.5" (120/60-17)
13,500 rpm
I'm going to try 55chevr's calculator again, too.
« Last Edit: December 20, 2014, 10:54:41 PM by sofadriver »
Mike in Tacoma
Bike #833
Offline sofadriver
« Reply #14 on: December 20, 2014, 11:07:05 PM »
duhhhhh
i was entering tire diameter where the cosportbike calculator was asking for rim diameter
i'll go stand in the corner now
Mike in Tacoma
Bike #833
