Well, the Montana Dodge Boys have decided to move ahead with building our V4F lakester for 2015. Fabrication starts early next year. I'm sure it's been tossed around here in forums before, but I can't seem to find any HARD DATA about rear axle and OD transmission parasitic losses. I'm not looking for, "I once read", or "Sparky Smith told me", or "In Australia"... because we all know pinions spin the opposite direction in the other hemisphere, right?
We do not spin our motor fast, so we need an extremely tall gear... taller than a 2.75. BUT, at some point we will be going to V4 and then blown V4 at which time we'll spin another 1000+ RPM. A blown XXO Chrysler will be on the horizon as well. I mention this because it means we might need ratios between 2.0 and 3.5 in the next 5 years.
We initially were looking at a Winter's Xtremeliner because of the available 2.0 and 3.08 Ring and Pinion options, but they're stupid expensive and way overkill for a V4F. The tech guy at Winters assured me that a V8 QC, even with the 3.78 R&P, would be more efficient than the Xtremeliner in our application.
We then thought about a Ford 9" like in our roadster, mostly because we already have ratios from 2.47 to 3.7, but from what I've read, 9" are awfully parasitic because of the low pinion position, and changing a pumpkin in a tank does not sound like much fun.
A salty veteran friend is hell bent on running an airshifted Liberty tranny with OD, but he must have more money than us.
I know Ford 8" are less parasitic than the 9" but we'd have to buy gears, and that doesn't address the issue of swapping it in a cramped tank.
I am leaning towards a Winter's V8 with 3.78 R&P, polished gears, and low drag seals & bearings.
So, here are the questions ~
1. Does a .8 OD tranny have more or less parasitic loss than a QC with a 3.78 R&P geared to a 2.5?
2. How much parasitic loss does the above QC have? DATA please.
3. How does the parasitic loss of the above QC compare to other rear axle options (other options must have a drop out pumpkin) DATA please.
Thanks for playing! See you on the SALT!
