fordboy628
« Reply #270 on: June 12, 2015, 07:27:40 AM » |
Hey Mike
What size is the carb? It looks BIG Bones
I have been through this many times. Carb "looks" too big. How does it run on test? OK? Good? Make more bhp? etc, etc, etc . . . . . . . Give the engine "what it wants", as long as the tq and bhp are "driveable". Oh, BTW, this means different things to different people.  Fordboy
I used to be a people person. But people changed that relationship.
"There is nothing permanent except change." Heraclitus
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
sofadriver
Offline
« Reply #271 on: June 12, 2015, 03:48:21 PM » |
Hi, Bones. Yeah, the carb looks huge but it's just a 34mm. The reed box we made to mount the 125 reeds makes the carb stick out another inch, too.
Mike in Tacoma
Bike #833 100cc A/G, A/F and APS/G (in 2019)
sofadriver
Offline
« Reply #272 on: June 14, 2015, 09:49:18 PM » |
Got a lot done this week but there's still a lot left. Can't get anyone to feel the urgency here. Done; handlebars, Dzus plates mounted for body and body mounted, front fender mounted, steering stabilizer. Kinda' done; engine mounts (tacked), expansion chamber turned 180deg (still need to cut it again to adjust angle), controls fitted. Yet to do; exhaust stinger, shift linkage, steering stops, all electrical, mount tail section, cut fuel tank to fit and move spigot, paint, windshield, dyno testing. (there's more I'm sure) Getting ready for the dyno is now the #1 priority. A local nice SCTA tech guy has offered to do a "tech for class" inspection. That's another priority. I may show up for Speedweek still in primer.  Pics are; the Harbor Freight trailer (folds to fit against the wall of the shop), cool-ish lower fender mount, controls being test fitted.
« Last Edit: June 14, 2015, 09:52:43 PM by sofadriver »
Mike in Tacoma
Offline
« Reply #273 on: June 15, 2015, 07:16:52 AM » |
What? Show up at SpeedWeek in primer? How gauche! You'd be the first-ever racer to do that.  It's looking great -- and you're not as far behind where you "should" be as you might think. Keep at it and thanks for letting us in on the fun.
Jon E. Wennerberg a/k/a Seldom Seen Slim Skandia, Michigan (that's way up north) 2 Club member x2 Owner of landracing.com
sofadriver
Offline
« Reply #274 on: June 23, 2015, 12:11:09 AM » |
Might have paint after all. Had to change welders. The slow pace (and a lot more ) was making me nuts. The new guy's much faster and we think alike. Looks like it'll be done by this weekend. Have to cut out and redo some of the other guys work. I'm not happy with it.
Mike in Tacoma
tauruck
« Reply #275 on: June 23, 2015, 12:19:45 AM » |
Finding the right welder is a big issue and I understand your frustration. Happy to hear you got the thing sorted. Your bike looks right and they say if it does it goes right too (not direction wise).
Old Scrambler
Offline
Going Fast - Slowly
« Reply #276 on: June 23, 2015, 08:54:54 PM » |
2011 AMA Record - 250cc M-PG TRIUMPH Tiger Cub - 82.5 mph 2013 AMA Record - 250cc MPS-PG TRIUMPH Tiger Cub - 88.7 mph 2018 AMA Record - 750cc M-CG HONDA CB750 sohc - 136.6 mph 2018 AMA Record - 750cc MPS-CG HONDA CB750 sohc - 143.005 mph 2018 AMA Record - 750cc M-CF HONDA CB750 sohc - 139.85 mph 2018 AMA Record - 750cc MPS-CF HONDA CB750 sohc - 144.2025 mph
tauruck
« Reply #277 on: June 23, 2015, 09:12:20 PM » |
Mike I wanted to ask about the "pipe" and where it ends up?. I know why you built it the way it is.  Thanks.
sofadriver
Offline
« Reply #278 on: June 24, 2015, 12:04:02 AM » |
Yeah especially when I'm paying for them. The guy just wont listen. Check these rear motor mounts that I have to cut out.......WTF??!! Glad I stopped him when I did.
« Last Edit: June 24, 2015, 12:24:56 AM by sofadriver »
Mike in Tacoma
sofadriver
Offline
« Reply #279 on: June 24, 2015, 12:22:38 AM » |
Mike I wanted to ask about the "pipe" and where it ends up?. I know why you built it the way it is.  Thanks. l I needed a stinger that was exactly 15" long and .74" ID. A tremendous challenge for the other welder. The new guy spent about 2 minutes in his junk pile and came up with a set of handlebars from a kids tricycle. .74" ! Welded 2 of the bends together and aimed it out the side. Voila'. Perfect! Took about half an hour. And it's chrome!  It exits straight out the side about 6" below my right elbow. Good ear plugs will be a must!
Mike in Tacoma
tauruck
« Reply #280 on: June 24, 2015, 12:26:22 AM » |
I had a feeling you'd want earplugs.  Were those mounts supposed to be finished as it appears?.
bones
Offline
« Reply #281 on: June 24, 2015, 06:52:01 AM » |
Hey Fordboy I didn't say the carb looked too big I was just asking what size carb he is using-- 2strokes like big carbs. My 80 cc uses a 34mm and my 125 uses a 38 or 39mm
I'm going to miss seeing Sofa run as I won't be at Speed Week- I will be at BMST and WoS. Good luck Bones
donpearsall
« Reply #282 on: June 24, 2015, 01:44:52 PM » |
Hey Mike, are you referring to the welder who did your frame or another welder? Also I see from the pic that it looks like the mount is welded to a saddle that is hose-clamped to the frame cross member. Was that his idea of the finished mount? Hard to tell how it is supposed to be from the photo.
fordboy628
« Reply #283 on: June 24, 2015, 03:11:08 PM » |
Bones, You are right, I stand corrected. My apologies as well.  Fordboy
sofadriver
Offline
« Reply #284 on: July 03, 2015, 12:31:09 AM » |
They were only tacked but, yeah, that was his idea of fancy motor mounts.  Pretty good seat mounts though. (if there was a seat!)
« Last Edit: July 03, 2015, 12:32:42 AM by sofadriver »
Mike in Tacoma
