Author Topic: F Class Engine For Sale  (Read 5527 times)
Offline Richard 2
  • 2 Richards Racing
« on: December 15, 2014, 06:16:41 PM »
For Sale, Fresh Esslinger 2777 cc Engine Bore 3.858 Stroke 3.625, ARRCA Head and Block (Aluminum)(Oringed), In 2010 I welded Flanges on the rear of the block for a Ford small block V8 bell housing, King 300M crank HD with Ford V8 Modular 8 bolt flywheel pattern, New Crower extra thick Rods, New JE pistons, Barnes dry Sump Pump with New Style Rotors, Rebuilt ATI Damper, The engine Was completely reworked by Esslinger in 2013 and ran on there dyno with out the Turbo. Has been oiled down and sitting in my shop sense. Never installed or ran sense. 719 Hp on Wheel Dyno and 835 Hp on bench Dyno in 2010 when I ran it in our Mod Roadster for two Records 209 mph and 219.648 mph and one Qualifying run at 225 mph with a Spin.
Also included one set of injectors, fuel rail t72 turbo, intake w/throttle body, SS Header, Flywheel and clutch.
$25,000
Richard 2
 40ne7- 6Six7-1Five7five
mcinroyconstruction@hotmail.com
« Last Edit: December 15, 2014, 06:19:17 PM by Richard 2 »
4 cylinder Esslinger
Could of had a V8
Offline Jack Gifford
Re: F Class Engine For Sale
« Reply #1 on: December 16, 2014, 02:15:20 AM »
What was the boost pressure on the 835 HP engine dyno session? And- do you have flowbench numbers for the intake ports?
M/T Pontiac hemi guru
Offline Richard 2
  • 2 Richards Racing
« Reply #2 on: December 16, 2014, 07:37:23 AM »
35lb of Boost
I do not have any Flow numbers.
 Brian at Esslinger could probably come up with some Flow numbers. (you would need to tell him it is the short engine)
« Last Edit: December 16, 2014, 07:41:55 AM by Richard 2 »
Could of had a V8
« Reply #3 on: December 17, 2014, 02:26:47 AM »
Thanks. The 35 PSI number sort of confirms that the simulation software for my 'F' class engine is at least in the ballpark. It shows that i'll need 30 PSI to make 725 HP (Roots blown on methanol). It's a 2-valve-hemi head with intake ports that flow 330 CFM @ 28 in. water, at .650" lift.
My hat's off to you on those records!
Offline dw230
« Reply #4 on: December 17, 2014, 11:52:09 AM »
Most F class record holding lakesters are currently making in excess of 1000 HP.
Offline Richard 2
  • 2 Richards Racing
« Reply #5 on: December 17, 2014, 08:00:05 PM »
Jack I have run 42lbs But it is hard on wrist pins, and connecting rods. Mostly because of heat.
   I made some changes on the tall engine that I run know to eliminate the heat problems.
This engine I have For Sale has the HD rods and Pins.
And if you run Gas run as much as it can take and still start.
« Last Edit: December 17, 2014, 08:05:27 PM by Richard 2 »
Could of had a V8
Offline Rick Byrnes
« Reply #6 on: December 18, 2014, 03:57:24 PM »
Nice package for a good price....
Are you going to an ST cyl head?
Rick
Offline Richard 2
  • 2 Richards Racing
« Reply #7 on: December 18, 2014, 09:06:23 PM »
Yes Rick I went to a tall head and a tall block.
Could of had a V8
Offline Richard 2
  • 2 Richards Racing
« Reply #8 on: March 23, 2015, 03:46:35 PM »
  This Engine could put you in the Two Club in the right car.
Could of had a V8
