Kustombrad
I agree completely. Years ago Mickey Thompson wrote an article on leaving the line. On launch, if the car fishtails right, add weight or preload to the right side, or visa versa, until it launches straight. On the drag strip, if you watch the down the track cameras, if they get out of the groove, they pull hard in the the direction of the tire that looses traction.
At Bonneville, cross winds may have something to do with which way it spins.
Back in the 60's when I had a service station, I could tell whether a car had a posi by which tire was worn the most (young hot rodders) If posi, left tire was worn more because of torque loading and more weight on left when both are spinning.
IIRC Smokey even turned one of his Hudson's engines backwards to try to balance out the traction issues. Until he was caught.
Ron
