Author Topic: EFI Injector signal,,  (Read 6463 times)
Re: EFI Injector signal,,
« Reply #15 on: December 11, 2014, 08:47:09 PM »
Here are a couple tid bits I've learned over the years......
Good info, thanks, and also the link Stainless posted is good and you and they are pretty much on parallel  lines of thought,
Offline Steve Cole
« Reply #16 on: January 09, 2015, 05:00:24 PM »
Injector timing at low engine RPM plays a big roll in response and emissions. Once your about ~ 3500 RPM not very much changes, as you are going to have to be on longer than the intake valve is open anyways. I've attached an excel spreadsheet I wrote that will show you whats happening. If you know your injector pulse width in mS and RPM, you enter those and the calculator will give you crank degrees required to do it.
