Author Topic: Wheel adapters  (Read 2423 times)
Offline flatman
Wheel adapters
« on: November 16, 2014, 11:01:41 AM »
Is it OK to use wheel bolt pattern adapters?
Re: Wheel adapters
« Reply #1 on: November 16, 2014, 11:40:35 AM »
More info required... but final say would be with the chair of the tech committee listed in the rule book.  What are you trying to do?
Re: Wheel adapters
« Reply #2 on: November 16, 2014, 11:42:37 AM »
I didn't see a reference to wheel adapters in the rule book but I would be leery of using them on a heavy car at high speed. Re-machining the hubs for a new bolt pattern is a better idea. I went through the same quandary and finally had my 5x130mm Porsche rear hubs re-machined for the standard circle track standard 5x5" pattern.
Regards, Neil  Tucson, AZ
