You can fit all the internals in a NACA-66 from plan view. I have seen it somewhere.....
I'm not saying impossible but still going to depend on what you have and what you will except for a total width. If you increase the width (frontal area) to get what you want in the car (wheels/tires if a streamliner) then the overall length might be shorter but with more frontal area. Still if the Cd is better it might make up for it. Lots of options one just needs to consider as many as possible.
In the smaller engine classes, say bike motors, this is easier. If you are in the larger engine sizes and running blown gas and have turbo/turbos, intercoolers, intercooler ice-water tanks, plumbing, main water tank, maybe a rad-in-a-box and so forth then I think you are ahead with a longer narrower car with the 7* taper at the back and a teardrop shape at the front vs. a wider car just to maintain the NACA profile, but that is just my opinion
. One thing I love about the lakester/streamliner (and some degree comp coupe) classes is we have a lot of leeway to mess around and at worst go home with egg on our face
I had the lakester set up with a teardrop shaped nose and an expanding width to just behind the driver and then it went to a 7* taper from there back. Now that I'm switching to a car engine I have to add 3 feet and will have a 3 foot length now just behind the driver (firewall) that will be a constant width/height. Not what I originally wanted but will now have
