Author Topic: Lenco CS-3 Gears  (Read 5907 times)
Re: Lenco CS-3 Gears
« Reply #15 on: September 24, 2014, 02:11:13 PM »
Went to see Al and his lakester --- the shift towers are in the center and the gears are 1" wide---he picked up a book some where  it has the gear ratios of both trans in it
I am late on this answer and yes Bob D. is correct. Al has a CS-1 unit and the lowest 1" gear available in either 6 or fine spline is 1.25-1. I have not talked to Lenco for a few years, and the last time I talked to them they quit their exchange program on gear sets, but it is always worth a try to call and ask if they have started it up again. You can convert a six to a fine spline but need to also convert the shafts. When I was buying parts for my CS-1 three speed years ago I was looking for 1.25-1 ratio's and had a hard time finding one. I hope for Al's sake it will be easier for him to find one.
Good luck on the search,
« Reply #16 on: September 25, 2014, 01:05:49 AM »
he had a 1.28 and that has been installed ---part of his has been converted to fine spline by cutting out and replacing and welding
