Author Topic: Flathead heads  (Read 3316 times)
Offline flatman
Flathead heads
« on: September 08, 2014, 09:37:35 PM »
Wilson & Woods 76cc heads
Re: Flathead heads
« Reply #1 on: September 08, 2014, 10:04:47 PM »
Offline flatman
Re: Flathead heads
« Reply #2 on: September 08, 2014, 10:59:37 PM »
Yes, however they don't have them in stock.
Offline ronnieroadster
Re: Flathead heads
« Reply #3 on: September 09, 2014, 08:43:45 PM »
Jerry give me a call
  Ron
Offline flatman
Re: Flathead heads
« Reply #4 on: September 11, 2014, 11:10:25 AM »
Found a pair. Thanks
They had a set of 74 cc heads.
I cracked a head at WOS so now I'll be able to make World Finals.
Re: Flathead heads
« Reply #5 on: September 11, 2014, 02:13:25 PM »
The head you cracked should be able to be welded. Aluminum heads are generally a fairly simple fix as long as distortion is properly controlled.
Offline saltracer1
Re: Flathead heads
« Reply #6 on: September 11, 2014, 08:00:10 PM »
Flatman, what car are you running? Inquiring minds want to know. Phil
Re: Flathead heads
« Reply #7 on: September 11, 2014, 08:29:51 PM »
Probably #7472 -- Wortman & Wortman Racing -- XF/BVFALT
Offline flatman
Re: Flathead heads
« Reply #8 on: September 12, 2014, 01:12:33 PM »
Than is correct.  Our car is #7472.  The heads that i cracked are stock iron heads that I opened up because I'm running 20 pounds of boost.  Problem is it weakens the heads.  The Wilson & Woods look like they have lots of extra metal that I can remove and still withstand the boost.
Re: Flathead heads
« Reply #9 on: September 12, 2014, 01:39:39 PM »
Offline GD
Re: Flathead heads
« Reply #10 on: September 12, 2014, 02:02:18 PM »
sent you a p.m.
Gord
Gord Driedger
53 Studebaker
Record holder Speedweek 2016 XF/FCC 162.698
Record holder Speedweek 2016 XF/GCC 158.978
