Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
Poured foam seat
« previous
next »
Pages: [
1
Go Down
Author
Topic: Poured foam seat (Read 3831 times)
kustombrad
Poured foam seat
on:
September 07, 2014, 03:30:56 PM »
After the interior is done on my car I plan on doing a pour in seat. There's probably 4 companies out there who make very nice SFI approved stuff. Anybody have a favorite?
My projects.
http://www.landracing.com/forum/index.php/topic,13660.0.html
http://www.jalopyjournal.com/forum/showthread.php?t=327069&highlight=project+49
bbarn
Re:
Reply #1 on:
September 07, 2014, 05:01:02 PM »
We used ISP. They have great support and do lots of engineering and testing. We've poured 3 of them with very good results. Read the directions, then read them again, THEN pour the seat. It is pretty straight forward.
tauruck
Re: Poured foam seat
Reply #2 on:
September 08, 2014, 12:31:55 AM »
Brad, I did my own bead seats. Same as the stuff available over there.
I did two I wasn't happy with for different reasons.
The third version is coming up as soon as I have someone to help me.
Hammer of the Heretics!.
http://s260.photobucket.com/albums/ii4/tauruck/
http://xlforum.net/vbportal/forums/showthread.php?p=3818629&posted=1#post3818629
Reply #3 on:
September 08, 2014, 08:43:47 AM »
I can see no way that a person could do a poured seat on their own. I've watched several being done and helped on a couple of others in a shop where they were done routinely. If you get in and out of the seat you can't move the filler where it needs to be plus you'd need to be more flexible than anyone I know to knead the filler into spots where it should go.
What, me worry?
Reply #4 on:
September 08, 2014, 11:42:34 AM »
A poured foam seat sounds attractive but doesn't it conflict with the SCTA ban on "plastic" seats?
Regards, Neil Tucson, AZ
jacksoni
Reply #5 on:
September 08, 2014, 12:26:00 PM »
I think the poured foam falls into the 1" maximum padding rule rather than the plastic seat issue which is the seat itself- normally aluminum or in the case of a liner or something might be steel sheet. I had plastic bucket seats in an old dune buggy and I think that sort of thing is what the rule is about. (particularly after seat failure in a crash lead to seatbelts loosening and not restraining the driver.) Padding collapse same issue ( no stock sprung type seats) lead to the 1" rule as I understand.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
Reply #6 on:
September 08, 2014, 01:09:30 PM »
The so called "poured" portion of the seat is only a liner. A proper support is still required. When the poured portion is finished and tested it is normally covered with a fireproof fabric.
kustombrad
Reply #7 on:
September 08, 2014, 11:37:08 PM »
It is only a "liner" as Pete says. The seat will be aluminum and I'm needing something to keep my boney behind from getting bruised!
My projects.
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
Poured foam seat
