Author Topic: 50cc Sidecar Scooter  (Read 47445 times)
Offline revolutionary
« on: August 19, 2014, 01:18:41 PM »
As we are slowly progressing on my main project http://www.landracing.com/forum/index.php/topic,13723.0.html , I had to do something to occupy my time, so I looked around the garage for something to play with  and all I could see was this little Honda scooter. After a little thought exercise and looking through the rule book, I saw that the SCTA guys don't like anything with small wheels to run on the salt, hence no scooters. BUT, looking closer, the Sidecar rules allow for wheels as small as 10 inches!! There are few other things like the wheelbase was too short and other minor things to be remedied, but in the end, I saw no reason I could not build and run a 50cc side car "motorcycle". So here she is...
Stock image
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
Re: 50cc Sidecar Scooter
« Reply #1 on: August 19, 2014, 01:22:29 PM »
Stripped down with 5 inch wheelbase stretch
starting of the sidecar
sidecar roughed in
Breaking Wind #9614
« Reply #2 on: August 19, 2014, 01:25:05 PM »
fancy dancy 24mm OKO slide valve carb and CT manifold
Engine swap to later model AF16 from the early AF05. Also, showing the Malossi Wild Lion pipe.
sidecar about done
Breaking Wind #9614
« Reply #3 on: August 19, 2014, 01:26:35 PM »
Go kart fuel cell
Breaking Wind #9614
« Reply #4 on: August 19, 2014, 01:30:16 PM »
ready for Speedweek (before the rain)
nitrous on a 2 stroke?!?!?!
Cyl head temp and steering damper
fuel shutoff - rewired the hi-lo headlight switch to turn off the fuel.  Also wired the horn button as the momentary nitrous switch
do you know how hard it is to find high speed rated scooter tires?? These are from Kenda
Breaking Wind #9614
« Reply #5 on: August 19, 2014, 01:32:29 PM »
steering damper -
even had a cushy little seat
Breaking Wind #9614
Offline tortoise
« Reply #6 on: August 19, 2014, 01:36:50 PM »
Nice! The FIM has a category for 50cc scooters. You could run without the sidecar at the Bonneville Motorcycle Speed Trials.
« Reply #7 on: August 19, 2014, 06:08:24 PM »
Nice build. What's the record going to be?. :cheers:
« Reply #8 on: August 19, 2014, 06:57:10 PM »
^^ I like your optimism!  Current record just over 62mph.  New record 63???  :-D
Breaking Wind #9614
« Reply #9 on: April 21, 2015, 10:43:28 AM »
I see all my links are broken.  Anyhow, here is what I started with
Then stretched to minimum 50 inch wheel base and did an engine swap to an AF16E
Then started working on a sidecar
Breaking Wind #9614
« Reply #10 on: April 21, 2015, 10:51:21 AM »
Got things together in hopes of heading to Speed week in 2014 but rained out
fuel cell using heavy duty nitrous solenoid in lieu of petcock
I've run the nitrous a couple times.  Not a big difference when using the little .008" jet, but when I put in the "big" jet (.015) it butted rings after about 10 seconds. Still need some tuning but it appears to be feasible to run a touch of nitrous if opening the ring gap. Experimenting necessary....
recently did some work inside
Breaking Wind #9614
« Reply #11 on: April 21, 2015, 10:56:08 AM »
Getting ready to head to Ohio in two weeks for some real test runs. Open record there, but with my current speeds about 50-55mph, I am far from the B'ville record of 62mph. Working on a cog belt drive system to get rid of the power-sucking vbelt/CVT system.
Home made pipe picked up 4mph over best aftermarket pipe.  not pretty but functional. Thanks to 2 Stroke Wizard software...
She's a runner...
Breaking Wind #9614
« Reply #12 on: April 21, 2015, 12:59:29 PM »
It looks like you are going to have fun!! Just go "slow" with the nitros.
« Reply #13 on: April 24, 2015, 09:29:50 AM »
Have you seen the record holder?  You appear to be running "naked" in a class that allows extensive streamlining.
Hard to make enough HP to overcome the drag penalty  :cheers:
« Reply #14 on: April 24, 2015, 09:53:04 AM »
Stainless, Streamlining will come down the road.  I will be running next weekend in Ohio to make sure all the bugs are worked out. Then I know I need a little more power, then do some aero work. 1/2mv^2 doesn't change, but at least it is not as noticeable at these low speeds. If I'm lucky I'll have something a little more competitive by August.
I know that the current record holder has a really dialed in combination and I have a long way to go.  :-D
Breaking Wind #9614
