Author Topic: Number plate Location on Small Bikes  (Read 5325 times)
Offline Strokerface
« on: August 13, 2014, 11:17:05 PM »
Not sure how to comply with the following rule set (bolded) for our small bike.
2.K.
Motorcycle number and class identification on both sides of the motorcycle are required for each participant. Numbers shall be reserved with organizer. The number class shall be displayed within a flat, smooth, vertical surface with a minimum dimension of 7.5 in high and 10.5 in wide, with a maximum of 8.5in by 11in. Motorcycle numbers must be a minimum of 3 in high and 1 in wide. Class designation shall be a min of 1in high. Numbers/letters shall not be shaded or outlined. The surface may be on the motorcycle, or number plates may be used. Where used, number plates shall have 1in radius corners, be securely mounted, meet the dimensions and be located ahead of a vertical line through the rear axle. Numbers shall be in full view and not blocked by the rider when in the riding position.
Does "located ahead of a vertical line through the rear axle" mean the entire plate, or the center of the plate? This bike is so small that locating the plate forward of the axle makes it hidden by the rider's leg. The plate shown in the photo below is a 6x9" oval. Will be replaced with 7.5"x10.5" but we are concerned about the location. Even getting the center of the plate forward of the axle puts most of it under the rider's leg. Sorry about the crummy angle of the photo but it's all I have.
Any advice very welcome!  :cheers: Jim
(175-A-CG based on 100cc frame)
« Last Edit: August 13, 2014, 11:25:10 PM by Strokerface »
Re: Number plate Location on Small Bikes
« Reply #1 on: August 13, 2014, 11:25:50 PM »
Jim, if you use a number plate the rear edge must be forward of the rear axle.  The numbers could be on the tail section as well.  The numbers could be located anywhere on the plate so they are readable
Offline AHG
« Reply #2 on: August 14, 2014, 02:22:30 PM »
The following is a recent addendum to the AMA supplemental rules.
2. K. NUMBER/CLASS IDENTIFICATION
within a reasonably flat, smooth, vertical surface
dimensions and shall not extend beyond the rear edge of the rear tire.
when in the riding position. A change in rider/class requires a
change of numbers/class identification on the motorcycle.
I was asked to provide this info., but will not be available on this site prior to the meet.
Any further inquiries please contact the other steward, Curtis Smith at smithcurtis@hotmail.com
Thanks
Drew
~ I CAN COUNT MY LIFE ON ONE HAND ~
Faith, Family, Friends, & Fast Motorcycles
Offline Strokerface
« Reply #3 on: August 14, 2014, 02:48:17 PM »
Well done, thanks!
Jim
Offline dw230
« Reply #4 on: August 14, 2014, 07:52:14 PM »
May I suggest that if the number plate is partially covered by the rider's leg is of no concern. The starter calls the number to the timing tower prior to the bike leaving the starting line. Do you really think that the timers, who are several hundred yards from the course, can read a 3" number with accuracy? I believe the procedure is done by all groups using the raceway.
« Reply #5 on: August 14, 2014, 09:24:15 PM »
Come on Dan, you're giving away all the secrets.
Offline Strokerface
« Reply #6 on: August 14, 2014, 09:55:33 PM »
I just want to pass tech.
Jim
« Reply #7 on: August 14, 2014, 10:10:25 PM »
Scooter takes you picture and files it by bike number.  It helps him if he can read it.
« Reply #8 on: August 19, 2014, 01:13:07 AM »
It is tricky to get the FIM class designation into a small area with 1 inch numbers.
« Reply #9 on: August 19, 2014, 10:12:09 AM »
looks like you left out the paint code.... surly the frogs require that info as well  :roll:
« Reply #10 on: August 19, 2014, 11:35:21 AM »
Looks like a ransom note.   :-D
Offline nrhs sales
« Reply #11 on: August 19, 2014, 12:25:40 PM »
all your bikes belong to us!!
Offline **RP**
« Reply #12 on: August 19, 2014, 06:54:01 PM »
Thanks
Drew
Are there any other Addendums to the AMA rulebook that entries need to know about before showing up at tech in a few days?
Ralph Pitlock
www.paintworkz.com
Offline Chris V
« Reply #13 on: August 19, 2014, 09:19:13 PM »
Yes, good thought, I wish I thought to ask that of that when AHG posted # plate rule. Hope it was the only one. AMA rules I don't see any addendums  :?
1972 Yamaha R5  350cc
